| EDM Machines Discuss EDM Machines here! |
Hi all, First post from me and I'm looking for a little information and advice. We have a Robofil 510 and a Roboform 810 at my workplace and I am having a little problem with the floppy drives. The Roboform 810 boots up off of 2 Double Density floppy drives and the 510 off of 1. DD disks are becoming a little hard to get hold of and also if the drives go, it costs us £150 for a replacement from Charmilles. Our boot up disks keep failing and trying to make new copied is becoming a little problematic. I have read a few posts on here about people trying to find alternative methods of doing this, but if there a simple thing to do to replace these floppy drives. I was wondering mainly if there is a way to modify a High density floppy drive to operate, or whether anyone knows of a cheaper source for them. Secondly, is there anywhere that supplies DD floppy disks anymore that aren't used. I have noticed that the 510 has a serial port on the side. I'm guessing there is a way to utilise that instead of using floppys to load the programs. Other options I've considered is whether it's possible to change the control units to something a little more up to date. I've also seen on retro computing sites people replacing the floppy controllers on BBC micros and old Acorn machine with either USB ports or CF card readers. I'm wondering if there is a possibility there. Any and all advice please. Marc |
Marc, Question, why do you need a floppy disk to boot up your 510? Do you actually mean that you need it to load software or do you really need it to boot up? If you actually must have it to boot up something is wrong. I have had similar issues to what you have mentioned. 2 of our 5 wire machines have the same control as your 510. The floppies themselves do seem to fail far often. Currently we download programs via RS232 instead of using the floppies for just the reasons you have mentioned. Although RS232 is not as nice as the floppies are (when they work correctly) it is simple and it does work. If you want to go that route I should be able to help you. You don't need any special software and many programming systems come with a DNC application. We use Windows Terminal. If I remember correctly it may have been part of windows 95. Not sure. It is just 1 .exe file with a help file that accompanies it. I keep telling myself I will get something else but I never do. Don't confuse it with Hyper Terminal. 1 drawback. You still need the floppy drive in working order to be able to reload software. You can't do that with RS232. Supposedly you can load the technology files off of the software disks via RS232 although I have not been able to. So we have working floppy drives that we use only to reload software when necessary and .tec files when we need something out of the ordinary. In theory you can/could buy the same floppy drive from Teac. I found it listed on their website although they tell me it is out of production. Have seen a few used ones on the net but they are always gone when I follow up. Haven't heard of anyone getting a high density drive to work. I have been told that the issue is not as much with the drive as with the machine software. Supposedly the software does not know that high density drives exist and therefore can't recognize them. These controls were pre USB so no luck there either. Would be nice though. I have purchased brand new still wrapped Verbatim DD floppys by the case on E-bay. Just keep your eyes open and be patient. (they still go bad too often though) Updating the control would be a nightmare. The control not only makes the machine move, it runs the EDM generator, all other machine functions, and provides the interface for us humans to communicate with the machine. This control is not flashy (and yes it graphs programs slowly) but it will do anything the machine tool is capable of doing. How long have you been running the 510? If you are used to Japanese machines it will seem quirky until you get used to it. Hope this info helps. If you would like any help with the RS232 just let me know. I am not too crazy about it myself but we use it because it works. Good luck. kip0569 |
| I have gone through the same process as kip. I may share some additional info regarding my experience with this (I have a Robofil 310): You can use HD disks and format them to 720. Cover the square hole in the corner of the 1.44M floppy with a piece of tape (there should be two holes - you want to cover the one WITHOUT the write-protect shutter). You can format them with a program called fmtw.exe which can be googled. I have used Windows XP for this. There are three disks. I made copies of them to the a hard disk and then back to floppys. Disk no. 1 did not work, the other two did. This is very important because if floppys fail and if there are no backups you are in big trouble. So, keep several backups of disks, especially the ones whose backup does not work from a hard disk (there must be hidden files or stuff like that). I have RS232 connection, so floppies are only used when the machine asks for initialization. Programs are always transfered by RS232. |
| I've deal with high end laboratory instrumentation and some of the older stuff boots its firmware from a floppy drive. I've been planing to experiment with one of these: YouTube - USB flash drive as a floppy disk in use - Floppy Emulatoror something similar. It might also work for you.Ken |
| charmilles d 10 | heartlnd | EDM Machines | 1 | 02-12-2010 01:07 PM |
| KM3P with Floppy drives | jimc80 | HURCO | 0 | 08-18-2009 10:18 AM |
| floppy drives | dertsap | General Electronics Discussion | 2 | 04-30-2007 09:04 AM |
| Anyone ever use floppy disk drives? | Bill Johns | Stepper Motors and Drives | 3 | 03-16-2005 05:02 AM |
| Floppy disk drives | Wjman | Machine Problems, Solutions , Wireless DNC, serial port | 12 | 05-20-2003 01:05 AM |
