Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 06-07-2010, 06:55 PM
Shawn Lucas is on a distinguished road
Charmilles Robofil 200 programs
Does anyone have some sample programs for a Charmilles Robofil 200? I am still waiting on my manuals from Charmilles. I get 2 files when I post from my CAM software. The first one is myprogram.cmd and the second one is myprogram.iso. The .iso file seems to be standard gcode but the first is a little strange to me. Any help would be greatly appreciated.
Old 06-11-2010, 01:52 AM
John@CRDM is on a distinguished road
Does your programme have multiple contours. The .cmd programme is often used to call sub programmes.
For example your .cmd programme might have all your start point coordinates and then call your programme after each move has been made
Old 06-18-2010, 04:44 PM
slucas_clmach is on a distinguished road
.cmd programs
Yes this appears to be the way it works on my machine.
Do you have a sample like this that I can look at?
I have a multiple fixture/part setup to do, right now I run one .iso program and then the other one.
Old 06-21-2010, 01:05 AM
That machine is a little older than I realised so not exactly sure on the control.
You could try something like this.
G0 X0 Y0
S101 (Service pack technology for rough)
M98 P1008 (Sub programme call)
G0 X0 Y0 (Linear rapid)
S102 (Technology setting for finish pass)
G77 P2 (Positioning at stored measured point)
S201
M98 P1009
etc......
Old 06-25-2010, 05:30 PM
Very good
Thanks, much appreciated.
Old 02-23-2012, 08:06 PM
redflower is on a distinguished road
Smile robofil 400 E694 FAILED
hello,good everybody .
Started *.ISO PROGRAM ,displayed E694 rear cover open,in my ROBOFIL 400.How any body know whats meanes.
Old 02-25-2012, 04:51 PM
Switch on rear of machine at the wire exit to the catch basket is not tripped or possibly the wire has gotten out of the basket and shorted on the machine somewhere. Don't forget to press other button (not wire feed button) above the wire supply roll to reset the rear cover open condition.
Old 03-26-2012, 04:54 AM
Smile
HI:
Thank you for your helop,the E694 was solved. but I don't know in the:SET UP-PARAMETERS,the ZDES、 HPA means?can you help?
Old 03-30-2012, 08:00 AM
new2edm is on a distinguished road
HPA is workpiece thickness
ZDES is Z draw...height above center of lower nozzle at which you want to draw
the contour..
Old 04-02-2012, 04:07 AM
Smile THANK YOU very much
Thank you for your help.now I need post of MASTERCAM 9.1 SP2 for ROBOFIL 400.and needs 852478 ccu exe CMOS chip program:978081,978553(?) for ROBOFIL 100.can you help me?my email :redflower806@yahoo.com.cn
and what'S means about :TEC table:C,P,Fn ,F,Sr,AJr,WSr,OFr.OF,HEDIT.and WIR table:OP,TE,TW,P,R,VE. C.AJ?
Tags
charmilles, gcode, robofil
Charmilles Robofil Wire Edm sundara Machine Problems, Solutions , Wireless DNC, serial port 8 05-07-2012 12:27 PM
Charmilles Robofil 200 startup Shawn Lucas EDM Machines 31 02-09-2012 08:34 PM
CHARMILLES ROBOFIL ALARM/MANUAL SINUMERIKO EDM Machines 11 03-29-2011 01:37 PM
Charmilles Robofil 440 Power Settings? Tool Maker 24 EDM Machines 0 09-10-2009 04:50 AM
Charmilles Robofil 300/310 Door Alarm WIRE CUTTER EDM Machines 11 07-25-2009 06:34 PM
