Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 06-01-2010, 06:57 PM
Shawn Lucas is on a distinguished road
Charmilles Robofil 200 operating process
I have recently purchased a Charmilles Robofil 200 and am trying to wrap my head around the operating process.
I understand a bit about the files but still have some confusion also.
Anyone familiar with this machine?
Old 06-07-2010, 06:33 AM
John@CRDM is on a distinguished road
Haven't got that exact m/c but we have some old chamrilles machines so i'm familiar with the controls. Has it got Charmilles control or fanuc?
Old 06-07-2010, 06:46 PM
Control + Flush
My machine has the Charmilles control not a Fanuc.
Another problem I am having is with the flushing, when I hit the button on the control to start the lower flush it comes on and works fine. When I press the button for the upper flush nothing happens. Is there something I need to do in order for it to come on?
Old 06-08-2010, 02:55 AM
What exactly is your confusion with the control? Not sure I can help with your flushing problem as i'm not familiar with the machine. It could be a mechanical or electrical fault or the top nozzle could just be blocked. Have you tried executing a flushing command to see if that works?
Old 06-08-2010, 08:39 PM
Charmilles tech support
As always after a call to Charmilles tech support they gave me a quick answer. On this machine when you are using brass wire the upper flush is not used. A switch to stratified wire and loading of the technology file should enable the upper flushing system.
My confusion on the control is that it is somewhat different from my other machines. So far I think I like it pretty well. Could you walk me through a typical job setup and run? Please be detailed as I am very new to this control and will need to take baby steps to get through.
Major confusion exists in the area of the .tec files and 'E' settings in the program. How do I know which setting to use? On my other machines, I am familiar with them enough to be able to just make the adjustments to the cutting parameters manually. Or I can look them up in the book and adjust as necessary.
Old 06-09-2010, 02:43 AM
It sounds like you'd benefit far more from spending a bit of money and having a days on site training with a Charmilles engineer. It's a lot to ask to expain an entire job set up in a clear way to a beginner purely in a text format.
Old 06-09-2010, 08:40 PM
slucas_clmach is on a distinguished road
Ok thanks I might need to do that.
Old 02-29-2012, 04:23 PM
glowplug is on a distinguished road
Hi all, just to ask if anyone has the cutting conditions for a wire machine charmilles robofile200, if I could provide a copy, I need to know the conditions for different types of materials and thicknesses, thanks in advance
Old 03-30-2012, 08:06 AM
new2edm is on a distinguished road
I think I can help you.. I figured all that allready
It is simple enough but.. I use user. tec as I do not have the right Tec file for my machine.
If u are interested give me a PM with your email and I'll try to teach you.
Charmilles Robofil Wire Edm sundara Machine Problems, Solutions , Wireless DNC, serial port 8 05-07-2012 12:27 PM
Charmilles Robofil 200 startup Shawn Lucas EDM Machines 31 02-09-2012 08:34 PM
CHARMILLES ROBOFIL ALARM/MANUAL SINUMERIKO EDM Machines 11 03-29-2011 01:37 PM
Charmilles Robofil 440 Power Settings? Tool Maker 24 EDM Machines 0 09-10-2009 04:50 AM
Charmilles Robofil 300/310 Door Alarm WIRE CUTTER EDM Machines 11 07-25-2009 06:34 PM
