Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > EDM Machines
EDM Machines Discuss EDM Machines here!
Old 03-24-2010, 11:37 AM
Toolz is on a distinguished road
Program for burning in the X direction?
I'm having a problem program a burn in the X direction as a undercut. I'm using a Charmillies roboform 51 with the SPS programing software. For some reason it keeps burning in the X positive direction when I need it to burn in the X minus direction. Anybody out there that can help would be very apprecated.
Toolz
Old 03-24-2010, 12:31 PM
Andre' B is on a distinguished road
I do not do a lot with sinkers but just a wild guess.
Do you have a C axis and is it spun around 180°?
Old 03-24-2010, 12:56 PM
Yes I do have a C-Axis but its not coming into play right now. All I'm tring to do is move off piece in the X in positive direction, Bring down my Z to depth (to do a undercut). Now start the burn cycle and burn(move) in the X minus direction. then come back to where I started then lift my Z up.
Old 03-24-2010, 04:57 PM
From what I can remember the burn program should look something like this.
The AXE/ X gets it burning in the X axis, the FROM gets changed to how far off the part your starting position is in the X in stead of the Z, and from there on it is the same as buring down in the Z.
I was working with a roboform 2000.
Code:
AXE/ X
FROM/ X,.1,Y,0,Z,0
DOWN/ L,-.2, ....
ORB .....
ORB .....
ORB .....,RET
Old 04-07-2010, 08:37 AM
John@CRDM is on a distinguished road
You've probably sorted it out but might help if you post the code.
I'd probably just use a vector command if possible
Need Help!- Burning my brass?!? Micro Milling General Metalwork Discussion 2 02-15-2010 09:09 PM
problem with program and direction woffler Mach Software (ArtSoft software) 7 02-16-2008 07:03 PM
The wood is burning studysession DIY-CNC Router Table Machines 2 05-06-2007 07:37 PM
Need Direction on 4th 5th? axis program Cappy GibbsCAM 3 04-20-2007 07:20 PM
drives burning up thespindoc General Metal Working Machines 5 04-03-2005 06:00 PM
