Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > EBAY ADS
EBAY ADS Post your Ebay ads here so the members can see what you find on ebay or are selling yourself!
Old 10-05-2009, 05:07 PM
Gold Member
heilcnc is on a distinguished road
MINI LATHE HEADSTOCK GREAT FOR 4TH AXIS
1 USED HEADSTOCK OFF A C1 MINI LATHE(SHOP FOX M1015) AND TAIL STOCK WITH MT#1 DEAD STOP THE HEADSTOCK COMES WITH ADAPTER TO MOUNT STANDARD "3 MINI LATHE CHUCK (PN-1187 YOU CAN GET FROM LITTLE MACHINE SHOP NO CHUCK INCLUDED!!!!) THE HEADSTOCK HAS MT#2 TAPER IN FRONT "3/8 BORE THRU HAS 28 TOOTH XL TIMING BELT PULLEY I ADDED TO IT EASLY REMOVED THIS WOULD BE GREAT TO MAKE 4TH AXIS OUT OF IT PRETTY SMALL HAS 4 BOLT HOLES ON FLAT BOTTOM OF HEADSTOCK ALLSO HAS KEYWAY RIGHT IN MIDDLE OF BOLT HOLES SHIPPING IN THE USA ONLY!!!!!!!!!!!!!!!!!!!!!!!!!! BIDDING STARTS AT $5 SHIPPING FLAT RATE $10.25
http://cgi.ebay.com/ws/eBayISAPI.dll...PageName=STRK:
USED MINI LATHE HEADSTOCK AND TAIL STOCK heilcnc EBAY ADS 5 09-27-2009 05:28 PM
Taig Headstock 4th Axis Conversion antiretrograde Taig Mills & Lathes 7 08-06-2008 01:14 AM
Model/dimensions of mini-lathe headstock noahl Vertical Mill, Lathe Project Log 2 02-09-2008 07:20 PM
Multi-Axis Fixed Headstock Automatic vs. Swiss perrettamachine General Metal Working Machines 0 09-01-2005 07:45 AM
Mini lathe headstock for Spindle rgillam DIY-CNC Router Table Machines 0 05-23-2005 08:59 PM
