Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > EBAY ADS
EBAY ADS Post your Ebay ads here so the members can see what you find on ebay or are selling yourself!
Old 09-26-2009, 04:21 PM
Gold Member
heilcnc is on a distinguished road
USED MINI LATHE HEADSTOCK AND TAIL STOCK
1 USED HEADSTOCK OFF A C1 MINI LATHE(SHOP FOX M1015) AND TAIL STOCK WITH MT#1 DEAD STOP THE HEADSTOCK COMES WITH ADAPTER TO MOUNT STANDARD "3 MINI LATHE CHUCK (PN-1187 YOU CAN GET FROM LITTLE MACHINE SHOP NO CHUCK INCLUDED!!!!) THE HEADSTOCK HAS MT#2 TAPER IN FRONT "3/8 BORE THRU HAS 28 TOOTH XL TIMING BELT PULLEY I ADDED TO IT EASLY REMOVED THIS WOULD BE GREAT TO MAKE 4TH AXIS OUT OF IT PRETTY SMALL HAS 4 BOLT HOLES ON FLAT BOTTOM OF HEADSTOCK ALLSO HAS KEYWAY RIGHT IN MIDDLE OF BOLT HOLES SHIPPING IN THE USA ONLY!!!!!!!!!!!!!!!!!!!!!!!!!! BIDDING STARTS AT $50. SHIPPING $9.75 FLAT RATE http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=STRK
Old 09-26-2009, 08:13 PM
Gold Member
this is small enough to make a 4th axis for a taig mill but this headstock is big enough to mount the standard "3 3 jaw chuck that comes with the 7x12
mini lathe it has a adapter to mount the chuck with the headstock if you have any other questions just ask thanks
Old 09-27-2009, 04:02 PM
Gold Member
if you want to build 4th axis this is perfect for it time is allmost up
Old 09-27-2009, 04:55 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Did you sell it?
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 09-27-2009, 05:02 PM
Gold Member
no sent you a privite message
Old 09-27-2009, 05:28 PM
Gold Member
jalessi no it did not sell sent you private message
Model/dimensions of mini-lathe headstock noahl Vertical Mill, Lathe Project Log 2 02-09-2008 07:20 PM
Tail stock wont Advance Jedi General Metalwork Discussion 2 11-15-2006 08:20 PM
Mini lathe headstock for Spindle rgillam DIY-CNC Router Table Machines 0 05-23-2005 08:59 PM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 10:16 PM
Quick release tail stock on 8x12 lathe balsaman Mini Lathe 9 10-12-2004 08:41 AM
