Results 1 to 1 of 1
Thread: CNC XY Mill Drill Lathe Table. Mach3 BobCad Full 4 Axis
    Mar 2010
    Buy this item on ebay:
    http://www.ebay.com/itm/120767912247
    or check out our ebay store:
    http://stores.ebay.com/modelshopcnc
    For questions about this auction you can contact us at sales@modelshopcnc.com.
    This system retails for $3474. Save $479 with this ebay special.
    PLUS FREE SHIPPING FOR AUGUST **
    BETTER HURRY FREE SHIPPING ENDS 8/31/2011.
    This auction also includes FREE Bobcad V21 Cad CAM software. $795 Retail Value.
    This auction also includes 620 oz/in Z Axis Motor.
    This auction also includes A-Axis Rotary Table.
    ** Free shipping applies to continental united states only everyone else will receive a discount.
    Turn your Mill or Lathe into a CNC without the hassle of conversion. Mounts like a standard vise.
    You are bidding on a New Model Shop CNC, Inc. 404 XY table and 4 channel 404 series Controller.
    Watch a video of a 404XY system in action here:
    http://www.youtube.com/watch?v=mkvdmS_rtUk]404XY Demo Rough.mpg - YouTube
    Included: Prewired 620 oz/in Z Axis Motor.
    Included: A-Axis Rotary Table. w/prewired 300 oz/in motor.
    Included: Remote Button (See photo). Retail value of $49.00
    Included: Z-Module Touch Pad (See photo). Retail value of $129.00
    Included: Mach 3 Software. We are an authorized Mach3 dealer.
    Included: Full license of Bobcad V21 3D which has a retail value of $795.00.
    (We are an authorized BobCAD reseller.)
    Included: Precision ball-nuts and lead screws with less than 0.0002/inch repeatability.
    It works as a CNC or a manual XY table.
    Controller includes:
    - (4) Motor Driver Channels
    - (2) I/O Ports with 2 inputs and 1 output each and 5V Supply (1A Max all ports)
    - (1) VFD Port with 10VDC Output.
    - Parallel Port Interface
    - Mechanical Latching Emergency Stop Switch.
    - Built in cooling fan
    System can be used for precision inspection, automated sonic welding, custom XY positioning, milling, lathing, manual drilling and much more.
    620 oz/in, Z Axis motor is INCLUDED.
    A 4th Axis rotary table is also INCLUDED.
    Machine parts that exceed our tables travel using multiple programs and moving the Mill table it is mounted to.
    Specifications are as follows:
    Table
    X Travel 10.5 Inches
    Y Travel 8.5 Inches
    Table Size 5.7 x 15.75 Inches
    Base Length 14 Inches
    Base Width 8.5 Inches
    Table Height 6 inches
    Motor Size 300 oz in
    Motor Resolution 2000 micro-step/rev.
    Accuracy 0.0002" / Inch
    Weight 65 Lbs
    Controller 404 series
    Supply Voltage 120VAC 8A
    Motor Voltage 48VDC 3.5 Max
    Accessory Voltage 5VDC 1A
    Controller Channels 4 (X, Y, Z, and A)
    Box Size 10” x 8.5” x 4”
    I/O Ports (2) 2 inputs / 1 output
    (1) Variable Frequency Device
    Emergency Stop Mechanical Latching
    Controller Interface Parallel Port
    Cooling 60mm Fan
    Weight 25 Lbs
    The system includes our standard 1 year warranty.
    Attached Thumbnails Attached Thumbnails CNC XY Mill Drill Lathe Table. Mach3 BobCad Full 4 Axis-404_system_resize.jpg   CNC XY Mill Drill Lathe Table. Mach3 BobCad Full 4 Axis-bobcadv21_resize.jpg   CNC XY Mill Drill Lathe Table. Mach3 BobCad Full 4 Axis-mach3_resize.jpg   CNC XY Mill Drill Lathe Table. Mach3 BobCad Full 4 Axis-rotary_resize.jpg
  1. Replies: 0
    Last Post: 03-25-2011, 12:41 AM
  2. Replies: 1
    Last Post: 10-25-2010, 01:56 PM
  3. CNC XY Mill Drill Table
    By ModelshopCNC in forum Product and Manufacturer Announcements
    Last Post: 03-27-2010, 03:20 PM
  4. 4th axis, Rhino, BobCad and Mach3
    By gabi68 in forum BobCad-Cam
    Last Post: 02-11-2007, 04:14 PM
  5. Table drill in a Mill
    By villas in forum Mechanical Calculations/Engineering Design
    Last Post: 09-12-2006, 11:22 PM
