This system retails for $1573. Save $479 with this ebay special.
Visit our ebay store:
http://stores.ebay.com/modelshopcnc
For questions contact us at sales@modelshopcnc.com
This auction also includes FREE Bobcad V21 Cad CAM software.
Use it to set up a mill or lathe.
Included: Remote Button (See photo). Retail value of $49.00
Included: Z-Module Touch Pad (See photo). Retail value of $129.00
Included: Mach 3 Software. We are an authorized Mach3 dealer.
Included: Full license of Bobcad V21 3D which has a retail value of $1995.00.
(We are an authorized BobCAD reseller.)
This auction is for a Model Shop CNC, Inc 404 Series 4 channel Contoller with 3ea pre-wired Nema23 300 oz/in stepper motors.
As Easy as 1,2,3.
1. Mount the Motors.
2. Install the Software and cables.
3. Run your program.
This system is ready to run. You provide the machine and the motor couplings and we provide the controller, motors, cables and software.
What is included:
1. 404 Series 4 Channel Controller and power cord.
2. 3ea Pre-wired 300 oz/in Single Shaft motors w/ 8' cables and home switches.
3. Mach3 Software and Manuals on CD.
4. Bobcad V21 3D Programming Software
5. 10' Parallel Cable.
6. 404 Series Instruction Manual.
Specifications:
Controller
Supply Voltage 120VAC
Motor Voltage 48VDC
Controller Power 400Watts
Controller Channels 4
Box Size 8.5” x 10” x 4”
Controller Interface Parallel
Motor Outputs 3.5A Maximum per port
Motor Connectors DB9
Controller Fuse 8A
I/O Ports (3) 6pin
Input DB25 (Parallel Port)
Motors
Motor Current 3.5A Max Speed/Max Torque
Motor Wires 4
Motor Length 2.6"
Shaft Diameter .250" with flat
Motor Connector DB9 (Male)
Controller includes:
- (4) Motor Driver Channels
- (2) I/O Ports with 2 inputs and 1 output each and 5V Supply (1A Max all ports)
- (1) VFD Port with 10VDC Output.
- Parallel Port Interface
- Mechanical Latching Emergency Stop Switch.
- Built in cooling fan
System can be used for precision inspection, automated sonic welding, custom XY positioning, milling, lathing, manual drilling and much more.
Motor features:
300 oz/in motor with a nema 23 mounting flange.
Extremely high power to weight ratio
Superior linearity (better microstep accuracy)
Low audible noise
Less torque drop at upper speeds
4 wire configuration
Our step motors feature an improved stator design wherein geometries are altered for greater torque output than other 2-phase step motors of comparable length.
The exceptional static torque profile makes it possible to use shorter motors than before in a given application. Since shorter motors inherently produce better speed vs. torque
characteristics due to lower resistance and inductance, the net result is an ability to push same loads at higher speeds or higher loads at same speeds. This makes these
steppers good candidates for some applications currently beholden to servos.
The new stator design also features improved linearity, the characterisitic most influential on microstepping accuracy. The better the motor's linearity, the lesser tendency
there is for micorsteps to stretch and compress. The RS motors rightly deserve the classification, "Microstep Optimized". Additionally, the motors are surprisingly quiet in
comparison to other stepper motors.
The system includes our standard 1 year warranty.
We have received a few questions about larger motors. This system is also available with 620 oz/in motors for an additional $35 per motor. Motor sizes can also be combined.
