- 9060 Laser Engraving/Cutting Machine FOR SALE - TORONTO, CANADA
FOR SALE ...100% COMPLETE, TURN KEY AND IN PERFECT WORKING CONDITION.
TOO LARGE FOR OUR OPERATION, WE ARE DOWNSIZING....AND NO ROOM....IT'S GOT TO GO! WE WILL ACCEPT A REASONABLE/BEST OFFER!
SOME DETAILS ABOUT THE LASER MACHINE:
- Laser-type: Sealed Glass
- Laser power: 90W Glass RECI tube - low hours - max 25 working hours
- Machine frame size: 1070Tall x 1060Deep x 1360Wide mm
- Machine frame size: 42.1Tall x 41.7Deep x 53.5Wide inch
- Crated weight with accessories: 250 KGs (551 lbs)
- Engraving area: 35.4 x 23.6 inches (900 x 600 mm)
- Motorized Worktable with about 9.45 inches (24cm)of usable height
- Engraving speed: 0-60,000mm/min
- Max cutting speed: 0-36,000mm/min
- Laser output control: 1-100% software setting
- Location precision: less than 0.01mm
- Highest scanning precision: 50-1000DPI
- Working voltage: 110VAC 50-60Hz
- Operating temperature: 0-45 degree
- Operating humidity: 5- 95% non condensing
- Minimum shaping character: English 1.0 x 1.0mm
- Graphic format supported: BMP,JPG,GIF,HPGL,NC,PLT,DST,DXF,AI ...
- Driving system: micro divided stepper
- Cooling mode: CW-5000 water-cooling and flow sensor safety system ( INCLUDED)
- Auxiliary equipment: Exhaust-fans, air-exhaust pipe, air-assist pump (INCLUDED)
- Work surface: Iron honeycomb
- Controlling software: LaserCut 5.3 and Leetro 6535/6565 DSP control system.
- Compatible software: TAJIMA , CorelDraw, AutoCAD, Photoshop
- Fixed cabinet frame for rigidity.
- Large Front/Rear doors for allowing items to extend out as they are engraved.
- Motorized Up/Down Table.
- Large motors for faster engraving speeds
- Reduction gear on X and Y axis to reduce "coin effect".
- Materials can extend through the front and rear doors to allow for a larger work product.
- Interior LED Work area light to help see products during laser processing.
- Easy access for interchanging the rotary attachment (INCLUDED)
- Red-Dot pointer to help you see the expected laser beam position.
- Auto Focus touch sensor to easily set the right height for best engraving and cutting.
- Work surface has a vacuum table built in the design. This can pull warped sheets material down to become flat.
- Parts tray for removing small parts or scrap from under the work bed.
WE ARE THE ORIGINAL OWNERS, PURCHASED NEW......AND WAS STRICTLY USED FOR LAMACOID PRODUCTION ONLY !
IF YOU ARE INTERESTED IN MAKING AN OFFER OR HAVE QUESTIONS, PLEASE EMAIL US AT: INFO@NORTHSTARGRAPHICSINC.COM
We are located in Toronto, Canada. Best for pickup, but we may assist with shipping it out.
- You may not post replies
- You may not edit your posts
Forum Rules
