Haas EC400 CNC HMC
Results 1 to 1 of 1
Thread: Haas EC400 CNC HMC
    Mar 2017
    Default Haas EC400 CNC HMC
    Hey All!
    I have a 2005 Haas EC400 HMC for sale.
    Original Paint, One Owner Machine was Cutting Aluminium Only. Equipped with 12000rpm, 60 tool side mount tool changer, Through Spindle Coolant, Expanded Memory. Cutting Hours 4308 Only. On our Floor now, fully powered / tested & is in Great working condition.
    2005 Haas EC400
    Make: Haas
    Model No.: EC-400-4AX
    Serial No.: 51653
    Year of Manufacture: 10/05
    Condition: Excellent, Original Paint Machine
    All specifications are approximations, and are subject to verification.
    Features:
    12000 RPM Inline Direct Drive Spindle
    VQCPS Probing System
    Full 4th Axis Dual Pallet Changer
    60 Tools Side Mount Tool Changer
    16 MB Expanded Program Memory
    Remote Jog Handle
    Rigid Tapping
    USB Drive
    High Speed Machining
    Advanced Tool Management
    Power Failure Detection Module
    User Definable Macros, Spindle Orientation and Coordinate Rotational Scaling
    Brush-type servo drive motors on all axis
    Programmable coolant Telescopic way covers
    Chip Conveyor
    Floppy Drive
    Tool Shelves
    High Pressure Coolant system
    Original Books
    Specifications:
    Travels:
    X-Axis: 20"
    Y-Axis: 20"
    Z-Axis: 20"
    Rapid Traverse Rates: 1000 Inch Per Minute
    Cutting Feed Rates: 710 Inch Per Minute
    Pallet:
    Dual Pallet Changer
    Pallet Size: 15.75" X 15.75"
    Pallet Change Time: 8 Seconds
    Weight on Table: 1000 lbs
    Spindle:
    Taper Size: CAT 40
    Speed Range: 0 - 12000 RPM
    Spindle Power: 30 HP
    Max Torque: 90ft-lb @ 2000RPM
    Automatic Tool Changer:
    Capacity: 60 + 1
    Max Tool Weight: 12 lbs
    Max Tool Dia: 6"
    Max Tool Length: 16"
    Tool Changing Time: 2.1 - 3.7 Seconds
    General:
    Air Required: 100 psi, 4 scfm
    Power: 220v / 66FLA / 3-Phase
    Overall Shipping Dimensions: 150" x 102" x 95" High ( Machine )
    Chip Conveyor, Coolant Tanks, Coolant systems Dimensions extra
    Weight: 20,000 lbs
    Attached Thumbnails Attached Thumbnails Haas EC400 CNC HMC-s-l1600-jpg   Haas EC400 CNC HMC-s-l1600-jpg   Haas EC400 CNC HMC-s-l1600-jpg   Haas EC400 CNC HMC-s-l1600-jpg
Haas EC400 CNC HMC
Haas EC400 CNC HMC
