CNC Router Table 48" x 48" with Vacuum Table, Touchscreen & more... | eBay
CNC Router table built to industrial specifications with ballscrew precision on all axis. Less than 1-Year old. Comes with Touchscreen PC loaded with LinuxCNC. Also includes CNC4PC C10 Controller Board if you want to use Mach3 instead. Also includes vacuum table.
Specifications:
Work Surface: 4-Foot by 4-Foot (4x4) by 7" Z-Axis
• Invertor: Huangyang HY01D523B VFD 220v
• Spindle: 1.5KW Water-cooled Spindle motor
• Water cooling system with reservoir and radiator mounted on Gantry
• 4 x High-precision TBI ball screw Q16mm pitch 5mm (C7).
• 25mm Precision Linear Rail Guideway with 12 V bearing blocks for Y X and Z.
• Digital Stepper driver: 24V to 50V
• Stepper Motor 600 oz In. NEMA 34
• Power Supply: Toroidal Power Supply PS-8N56R5R12 w/ 2 FM-3 modules
• Auxiliary switch for Dust Collector
• Hand Vacuum for clean up attached to Vacuum Table
Note: Dust shoe in photo not included.
Email me at matt at mattandmel dot com for questions or to come see it.
