- Haas VF-2SS VMC 4th Axis Ready
Haas VF-2SS VMC
This One Owner Machine has 9813 Cutting Hours only, 12000rpm, 24 tool High speed Side Mount tool changer, 1400 IPM, 16MB expanded Memory and many more features. All Original Paint, On our Floor now, fully powered / tested & is in Great working condition.
If you have any questions regarding this machine, please contact us at (909) 919-9600 or sales@machinestation.us
MachineStation | 4590 Eucalyptus Ave. Chino, CA 91710
Make: Haas
Model No.: VF-2SS
Serial No.: 39459
Year of Manufacture: 12/2004
Condition: Very Good
All specifications are approximations, and are subject to verification.
Features:
12,000 RPM Direct Drive Spindle
4th Axis Ready ( drives and wiring installed )
1400 Inch Per Min. Rapid
Rigid Tapping
MPG Hand Wheel Control
User Definable Macros, Spindle Orientation and Coordinate Rotational Scaling
Brushless servo drive motors on all axis
24 + 1 automatic high speed tool changer
Programmable coolant
Telescopic way covers
Chip auger
Flood Coolant system
Specifications:
Travels:
X-Axis: 30"
Y-Axis: 16"
Z-Axis: 20"
Rapid Traverse Rates: 1400 Inch Per Minute
Cutting Feed Rates: 833 Inch Per Minute
Spindle Nose to Table (Min.- Max.): 4" - 24"
Table:
Length: 36"
Width: 14"
Number of Std T-Slots: 3
Max Weight on Table: 1500 lbs
Spindle:
Taper Size: CAT 40
Speed Range: 0 - 12,000 RPM
Spindle Power: 30 HP
Max Torque: 90ft-lb @ 2000RPM
Automatic Tool Changer:
Capacity: 24 + 1
Max Tool Weight: 12 lbs
Max Tool Dia: 5"
Max Tool Length: 11"
Tool-to-Tool (avg.): 1.6 seconds
Chip to Chip (avg.): 2.2 seconds
General:
Air Required: 100 psi, 4 scfm
Power: 220v / 66FLA / 3-Phase
Overall Dimensions: 89″ x 92″ x 104″ High
Weight: 9200 lbs
- You may not post replies
- You may not edit your posts
Forum Rules
