- Carbide Micro Drills .25-6.7 MM
Here a ebay link to just one auction.
4.4 mm Inverse Drill Bit ID30C Union Tool 3.175mm Shank 10 PCS CNC Router PCB | eBay
only a small portion of the drills are listed. I have thousands of drills ranging for .25mm to 6.7mm is size. All have .125" shank.
Please contact me if you are looking for a specific size. I haven't had time to list all of them.
these came from the PCB manufacturing world but also work great for Aluminum, Brass and other non Ferrous metals. I have drilled mild steel with 1mm and larger without issue.
Email me if you have questions.
jim.kossow@att.net
TNX Jim
- You may not post replies
- You may not edit your posts
Forum Rules
