- Sieg SX2P milling machine in great condition with many perks (Edinburgh UK)
Please see Gumtree add with pictures here:
https://www.gumtree.com/p/other-powe...rks/1211887088
I am selling my Sieg SX2P HiTorque Mill with upgrades and tooling.
The mill is the one sold by ArcEuroTrade (UK), product number
080-030-00300. The mill has been upgraded with the large table (SX1L) and the LittleMachineShop air piston to support the head. The mill features a belt drive that is quieter and more resilient than gears. The spindle motor is a 500W brushless motor.
The mill is in great condition, purchased on the 28/7/2014 with some 100 hours of use. You will get a copy of the purchase receipt as well as the machine's instruction manual. The mill has an R8 metric type spindle.
Together with the mill you get:
- All tools supplied by the manufacturer (spanners, allen keys etc)
- Purchase receipt and Instruction Manual
- Protective cover
- ER20 12-piece collet set ( 2-13 mm) from GlosterTooling UK
- ER20 R8 collet chuck ( 7/16”UNF drawbar) in its box and collet nut spanner
- Unused mechanical edge finder in its box, 10mm shank, 4mm tip, 90mm length
- Set of RUKO M3 taps
- 4 tap wrenches
- Jacobs chuck (up to 13mm drill bit) with R8 arbor as supplied with the machine
- Unused spring tap guide in its box
- Dial test indicator in its box, 0.8mmx0.01mm
- Stuarts micrometer blue (engineer's blue)
- 2x Stevenson’s Metric 10-20-40 Blocks (10x20x40mm M6 Tapped & Clearance)
- Large right-angle block
- 300mm vernier height gauge and scribe
- magnetic base with dial indicator
- virtually new spray bottle of WD-40 cutting fluid
- spray bottle of white lithium grease
- virtually new bottle of Mobil 1 oil
- 4-piece engineer's square set in box
- 24pc Clamping Set 8mm (M6 thread)
Happy to answer questions. The bench the machine is on is also for sale. It is a hardwood top, 1.8 m long, heavy duty powder coated steel frame bench. The machine is positioned at one end leaving about 1.5 meters of workspace. I have added an oil, solvent, impact and puncture resistant rubber top. Please ask if you are interested as they make a nice combo.
Re: Sieg SX2P milling machine in great condition with many perks (Edinburgh UK)
- You may not post replies
- You may not edit your posts
Forum Rules
