- Metalworking & measuring tools from USSR at Ti.TOOLS Ebay store
Hello, community. I've decided not to multiply new threads, but lead one topic in this section. Little introduction:
I offer a wide range of metalworking & measuring tools, machine tool accessories, cutting tools, diamond & cbn grinding wheels etc.
Most of the tools I sell were produced in the former USSR & possess top quality. New or used, but immaculate and fully functional.
Some tools of the soviet era are quite unique or rare worldwide, though very functional & distinctive.
I've highlighted them in bold red with some remarks. I think they might be interesting for international community.
So here is the list:
- DIAMOND GRINDING WHEEL AC6 200-40-76mm GRIT 120 (125/100) Diamant-Schleifscheibe
- DIAMOND GRINDING WHEEL 1А1 125-32-32mm GRIT 500 (60/40) Diamant-Schleifscheibe
- T-Slot cutter (9 pcs Set) HSS
- Lathe threading die holder attachment MT3 (Morse Taper 3) doesn't reinvent the wheel, but has interesting design
- LATHE TOOL HOLDER + 10 CBN / BLACK DIAMOND Inserts for Hardened Steel / Carbides machining HRC 88-90
- Spade Drill MT4 (Morse Taper 4) D=32mm
- Spade Drill MT3 (Morse Taper 3) D=24mm
- Thread Rolling Die Head - M1 (rod/spoke threading head) - rare worthy tool
- Thread Rolling Die Head - M1.4x0.3 (rod/spoke threading head)
- Thread Rolling Die Head - M1.6x0.35 (rod/spoke threading head) Gewinderollkopf
- Thread Rolling Die Head - M2x0.4 (rod/spoke threading head) Gewinderollkopf
- Thread Rolling Die Head - M2.2x0.45 (rod/spoke threading head) Gewinderollkopf
- Thread Rolling Die Head - M2.5x0.45 (rod/spoke threading head) Gewinderollkopf
- Gear Shaper Cutter Module M2 (3 pcs Set)
- Gear Hob Cutter Module M3.25 HSS von UdSSR
- Gear Hob Cutter Module M4 (Special) HSS von UdSSR
- Gear Hob Cutter Module M8 20° HSS von UdSSR
- Center Drill Holder MT4 (Morse Taper 4) +2 center drills I've seen such holders on ebay, but not polished & tempered
- INDEXABLE TOOLHOLDER CTGNR 2525 M16 for TNG carbide inserts (Klemmhalter CTGNR)
- Reamer MT4 (Morse Taper 4) / Reibahle MK4 HSS (Morsekegel 4)
- Reamer MT3 (Morse Taper 3)
- Reamer MT2 (Morse Taper 2)
- Indexable insert centre drill Ø 40 mm
- Indexable insert centre drill Ø 25 mm
- Centering Microscope Zentriermikroskop "CO-2" (MK4 / MT4) #4 from USSR it's the 4th one I sell, high quality at decent price
- Triangular Straight Edge L 320 mm
- Square Straight Edge L 200 mm
- Mitutoyo VERNIER HEIGHT GAGE 0-450mm (0.02mm) / 18" (Höhenmesser Höhenreisser)
- TESA 75-88mm (0.005mm) Internal Bore Micrometer Dreipunkt Innenmikrometer
- Vernier Caliper 160mm (0.05mm) + Jaw Scribe Attachment very useful attachment used widely in former USSR, never met it abroad
Shipping: FREE to Europe, N. & S. America, UK
I will gladly answer your questions!
BTW. You can make requests on certain tools. I have way more stuff unlisted.
- You may not post replies
- You may not edit your posts
Forum Rules
