Hi Tom
I am ok with limit/homing switches, I need wiring diagram for spindle relay
output, I would prefer to use solid state relays that accept a 3V input,Thanks
Hi Tom
Hi Itran2000,
What will you be switching on your Spindle? The main power? Or just enable and direction? At what voltages and currents?
Regards
TK
http://dynomotion.com
I know how to set enable and direction, I just need how to hook up solid state relay that accept 3V input to what pin on kflop, my spindle is 220v-10a
Hi Tom
I think I know how to set spindle relay output for Kflop+gecko, I use bit 0, and relay(-) to gnd and relay(+) to JP7 pin 7, how much load can this pin output, otherwise I will use opto 4n35.
Hi Itran2000,
That sounds correct. Pin7 (all the KFLOP IO without pull downs) can source 16ma.
Regards
TK
TK
