Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 60
Thread: KMotion CNC.net
  1. #37
    Registered Need TECH Help!'s Avatar
    Dec 2007
    U.S.A.
    Changed to pos but ther is no movement of DROs they just stay at 000.000. All 3 DROs.
    Thanks,
    Troy
    [url]http://www.homecncstuff.elementfx.com/[/url]
  2. #38
    Dec 2007
    U.S.A.
    This fixed it.
    Thanks Brad,
    Troy
    "Brad wrote-Yahoo Forum
    > Hello Troy,
    > We need to set a flag as well, sorry about that….
    > In the top of your Index.html file you will see a script section similar to this::
    > $(document).ready(function() {
    > window.external.UpdateCommandButtonText(11,20);
    > window.external.RefreshInterpreterState();
    > window.external.InitInterpreterData();
    > $('[data-commandid]').click(function() {
    > var id = $(this).attr('data-commandid');
    > window.external.RunUserCommand(id);
    > Add this line after window.external.UpdateCommandButtonText(11,20);
    > window.external.ShowPosition = true;
    > And then your position html elements will be updated.
    > -Brad Murry
  3. #39
    Dec 2007
    U.S.A.
    Now for the next one.
    How to program a button for each axis to Reference the axis off of my limit switches.
    Attached is the C program i currently use with Mach3. Would this be needed?
    Where to start?
    Thanks,
    Troy
    Attached Files Attached Files
  4. #40
    Dec 2007
    U.S.A.
    This worked great Tom.
    Thanks again,
    Troy
    "-------- Original Message --------
    Subject:Re: [DynoMotion] Re: KMotion CNC.net
    Hi Troy,
    Yes you can basically use that same code. But there is a difference. Mach3 sends a message for each axis it wishes to home. So the one Home program gets called one time for each axis with a "flags" variable telling the program which of the axis Mach3 would like to home each time.
    The simplest thing would be to modify that program to home all 3 axes in sequence. Then add a single button in either KMotionCNC or KflopWebNC to call that one program to home all the axes.
    Your current program has "if" statements so it only homes each axis "if" it was told to do that particular axis. I will remove the "if" statements so runing the program will always home all of your three axes in sequence. I will also change the order of the code to be Z first then X then Y.
    I uploaded it to your Yahoo Directory
    http://tech.groups.yahoo.com/group/D...%20KflopWebNC/
    You can test it by running it from KMotion.exe | C Program Screen
    Regards
    TK
  • #41
    Dec 2007
    U.S.A.
    Brad,
    When adding trying to add a C program to a new button in the settings page, the "Browse for file" button does not work, but if i type the file address in the block, that is accepted.
    Sumthinelse for list?
    Troy
  • #42
    Registered bradodarb's Avatar
    Oct 2004
    Hello Troy,
    Did you try my internet security options I suggested on the Yahoo forum?
    I'm hoping it will get your file button working.
    -Brad Murry
  • #43
    Dec 2007
    U.S.A.
    Ummm.....
    I got the "run as admin" post, and i posted back that iam already admin. Is this the one your talking about?
    Troy
  • #44
    Oct 2004
    Hello Troy,
    Sometimes just because your login is admin, does not mean the program will run with administrqative rights.
    After some thought I do not belive it should need to run as admin, it is most likely an Internet Explorer settings issue.
    Before we get into that, send me the settings.html and your KflopWebnc.exe so I can be sure nothing is wrong with your release.
    -Brad Murry
  • #45
    Dec 2007
    U.S.A.
    I opened my Settings html and all fields are blank??? But fields are there within KflopWebNC.
    Troy
  • #46
    Oct 2004
    Hello Troy,
    Where did that file come from? c:\Dyno Install\KMotion\Release\Site ?
    It gave me a bunch of invalid character errors...
    Try this one::
  • #47
    Dec 2007
    U.S.A.
    C:\KMotion429z\KMotion\Release\Site
    Troy
  • #48
    Oct 2004
    Hello Troy,
    Did you get the same results with the file I sent you?
    -Brad Murry
  • Page 4 of 5 FirstFirst 12345 LastLast
    LinkBacks (?)
    1. Mach3 with Kmotion USB controller
      By DennisCNC in forum Mach Software (ArtSoft software)
      Last Post: 03-31-2008, 10:14 PM
