That is a thing of beauty and a joy to behold! You dont have a "cash for clunkers" program for my gecko 203v's do you? JK...
Are closed loop steppers handled on this board alone or do encoder signals need to go directly through the Kflop?
-Brad
Announcing Dynomotion's New 4-Axis Stepper Driver - KSTEP
•Quad 240W Microstepper Amplifer
•Plug-n-Play with KFLOP
•16X Microstepping
•5A @ 48V Max
•Super High Efficiency 17mohm MOSFETS
•Opto Isolation
•Mixed Current Decay
•500K steps/sec
•Regenerative Voltage Clamping (1KW peak)
•includes 1 Opto Isolated Analog Output
•includes (16) 12-24V Opto Inputs
•includes (2) 30v @ 0.1A Opto Isolated Drivers
•$199
Order here. More info here.
TK
http://dynomotion.com
-Brad
Hi Brad,
Thanks. If you wish to run closed loop steppers with encoders you must connect those back to KFLOP. Typically JP5 would be used.
Regards,
TK
Can you connect two of these to a KFLOP? I need 6 motors on my new router.
Yes you can connect two KSTEPs to KFLOP for 8 motors. You will use the RJ45 connector from KFLOP for the second set of Step/Dir signals.
It isn't convienient or really practical to utilize the extra IO on the second board however.
Regards
TK
I have been looking at your Kflop system for several weeks and this latest addition looks to be very nice addition. Does the Kstep board contain any over-current or short-circuit protection?
Thanks,
Robert
This is a very sweet driver! (Tom let me buy one a few weeks ago) It is like a G540 on steroids (for less money)! If you order one, I should mention one small caveat, like the G540, there is an "Enable" input that must be set "High" in order for the KStep to function. If you are using a KFlop as the signal source the proper KFlop bit is 45, configure it as an output and set it high.
If there is any interest I will set up a KStep with Mach3 (no KFlop) and report on it, but honestly it should be a very easy set up. I see no reason the KStep shouldn't meet the needs of even the most demanding NEMA23 systems and many NEMA34 systems.
Good Luck TOM!
Fish
Besides the normal current regulation setting no it doesn't. Miss wiring the motor or power supply is likely to cause damage.Does the Kstep board contain any over-current or short-circuit protection?
KSTEP does have over-voltage clamping and protection which we feel is a common failure mode in other drives. It also has under-voltage lockout.
Regards
TK
Now for the big question: Does this drive have midband resonance compensation?
Well KSTEP does seem to have excellent mid band characteristics due to the mixed decay current feedback and control. We have had all favorable reports while being compared to high end drives. KSTEP is not intended to be the “Best Money Can Buy”. It is designed to be at the sweet spot of price, performance, efficiency, resolution, and ease of use.
Regards
TK
I'm on the fence between KStep and Gecko, actually though I've decided on KFlop. One thing that I'm wondering is that I'm looking at 3.5A motors, but it looks like I have to either over or under drive these motors with KStep. I'm assuming that the current limit jumpers are just selecting sense resistors. Does that mean that I could solder an additional sense resistor to a jumper and get a 3.5A current limit?
I also don't see an idle reduction, but I'm assuming that it would be very simple to add one by PWMing the enables when motion isn't detected for a certain amount of time. Is that right?
I'm not a'scairt of no short circuit protection, though
I'm brand new to CNC, though I do have a background in automation. I'm intending to use this in my instrument building business.
Thanks for any help....and hello, BTW
edit: one more question too
If midrange resonance ends up being a problem in my particular setup, I wonder if anyone has developed a filter for KFlop to suppress it.
Thanks again for any info you might offer. Seems like KStep is very well thought out.
-John
