I would like to know the max allowable values and practical values for feed forward. What happens when you apply to much or to little? I believe things are becoming much easier to understand but my biggest problem in understanding a lot of the features is not knowing what my limits are. If 0-1 is the limit I can understand it as meaning 0-100 percent. If 10000000 is the max I can still break it down into 0-100 percent. Are there areas that negative numbers would apply? I assume there is a point where adding a higher amount of something above a point does nothing or is then becoming a bad thing.
Those will help me understand a lot I believe. I know it may be just me but knowing my limits helps me set boundaries I can really understand. If there are no limits I can except that to. Thanks.
Judleroy
LinkBack URL
About LinkBacks
