Newbie Modbus/rs232
Results 1 to 5 of 5
Thread: Modbus/rs232
    Jan 2018
    Question Modbus/rs232
    We just bought kflop/kanalog, I read manuals but our English is not so great and we can't understand few moments.
    We are using Analog drives +-10V, Lathe machine.
    I have few questions:
    1. How I can send RS232 command on M3 and Move commands?
    2. All C code should be in one init.c? (tool change,configuration,buttons,limit switches etc) If not, how we should upload multiple to kflop.
    Can I define sending RS232 command on m3 in init.c
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Modbus/rs232
    Hi Niyaz,
    See the RS232 Examples such as \C Programs\RS232\BufferedRS232.c I don't understand what Move Command you are referring to.
    Usually a Tool Change Program can be invoked when needed and run in another Thread and Program.
    Limit switches don't normally require any C Program to operate. They only need to be configured.
    But yes all continuous operations like monitoring push buttons can normally be placed in one forever loop in the init.c program. One single loop can monitor multiple things. See:
    KFLOP C Programs - Dynomotion
    Regards
    TK
    http://dynomotion.com
    Jan 2018
    Modbus/rs232-jpg
    Thanks for reply.
    Our electricians made system like on this diagram. All automatic switches controlled from external contorller. So on "program start" it should send command to power on drives.
    Attached Thumbnails Attached Thumbnails Modbus/rs232-jpg
    May 2006
    Hi Niyaz,
    Sorry I don't understand what you are asking.
    I suppose by "Automatic Switches" you mean relays?
    It seems to me when you initialize your system with the Init.c program it could send the RS232 command to power on the Drives.
    Your Init.c Program forever loop could monitor KFLOP Axis Enables and if they ever become disabled you could send the RS232 command to power off the drives.
    Regards
    TK
    Jan 2018
    Yes, relays
    Thanks, Ill try it.
Modbus/rs232
Modbus/rs232
