Problem with K-flop after shpindle starting
Results 1 to 4 of 4
Thread: Problem with K-flop after shpindle starting
    Dobro's Avatar
    Jul 2017
    Default Problem with K-flop after shpindle starting
    Hi all!
    I have a problem with K-flop.
    My configuration is K-Flop+Konnect+24K Shpindle+Danfoss VLT Micro FC 51
    Spindle Speed Control by PWM to Analog on 62 and 63 pin of Konnect
    When I start Spindle and try to change speed, Kmotion CNC freeze and disconnect from Kflop until fully power off.
    For speed control I use this C file:
    HTML Code:
    #include "KMotionDef.h"
    #include "CorrectAnalogFunction.c"
    #define C 0.00029f // 1000uF
    #define R 100.0f // 100 ohms
    #define Vcc 11.230f // supply voltage
    #define HIGH_BIT 62 // This output drives Cap high
    #define LOW_BIT  63 // This output drives Cap low
    #define RPM_FACTOR 24000.0 // RPM for full duty cycle (max analog out)
    // desired speed is passed in variable 1
    void ServiceKonnectPWM(void);
    int CorrectAnalog(float v);
    double T,T0 = 0;
    float Vout = 0.0; // desired voltage
    float V240=0.970;
    int correct;
    float V[]={
    0.001,  // count = 0
    0.031,  // count = 1
    0.044,  // count = 2
    0.054,  // count = 3
    0.062,  // count = 4
    0.069,  // count = 5
    0.074,  // count = 6
    0.079   // count = 7
    float SpSet = 0;
    main()
      SpSet = *(float *)&persist.UserData[1];
      //correct = CorrectAnalog(SpSet/RPM_FACTOR);     			// Set PWM
      //printf("Spindle Set V %f, Cor: %d \n",SpSet, correct);
      //Vout = SpSet / 195.5;
      Vout = SpSet / 3910;
    printf("Spindle Set %f Vout:%5.2f\n",SpSet, Vout);
    for(;;){
       T=WaitNextTimeSlice();
       ServiceKonnectPWM();
       //Vout = *(float *)&persist.UserData[1];  		// value stored is actually a float
    void ServiceKonnectPWM(void) {
        static int FirstTime = TRUE;
        static float Vc = 0.0f;
        static double T0;
        static int State;
        double T = Time_sec();
        if (FirstTime) {
            FirstTime = FALSE;
            T0 = T;
            State = 0;
       else {
          float V,I;
          // Compute Voltage applied to Cap
          V = Vcc*State;
          // Compute current
          I = (V-Vc)/R;
          // Compute new Cap Voltage
          Vc += I/C*(T-T0);
          // determine next state
          if (Vc > Vout) {
             ClearBit(HIGH_BIT);
             SetBit(LOW_BIT);
             State=0;
          else {
             ClearBit(LOW_BIT);
             SetBit(HIGH_BIT);
             State = 1;
          T0 = T; // save time when applied
    	int r;
    	float v2=2.0f*v;
    	// compare with half way points to determine closest count
    	if (v2 < V[1]+V[0]) return 0;
    	if (v2 < V[2]+V[1]) return 1;
    	if (v2 < V[3]+V[2]) return 2;
    	if (v2 < V[4]+V[3]) return 3;
    	if (v2 < V[5]+V[4]) return 4;
    	if (v2 < V[6]+V[5]) return 5;
    	if (v2 < V[7]+V[6]) return 6;
    	// must be 7 or higher do linear interpolation
    	r = (int)(7.5 + (v-V[7])/(V240-V[7])*(240.0f-7.0f));
    	if (r>255) r=255;
    	return r;
    P.S. English isn’t my first language, so please excuse any mistakes.
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Problem with K-flop after shpindle starting
    Hi Dobro,
    I think the issue is this program contains a forever loop so the program never finishes. If the S action is configured to wait for the action to complete, then whenever KMotionCNC invokes the action it results in a hang. Our later Test Versions should timeout in such a case. You forgot to tell us how you configured KMotionCNC or what Version you are running.
    The Konnect PWM needs to be serviced continuously by software. So the best solution would be to call the ServiceKonnectPWM function from a forever loop in your Initialization User Program and not here in your Speed Change Program. If you do so then the Speed Change Program shouldn't need to do anything (change it to an empty main) program. Whenever the Speed is changed KMotionCNC will set the KFLOP Persist variable to the new speed which will be picked up and used immediately. To have the new value picked up you will need to move the 2 lines below inside the body of ServiceKonnectPWM function
    Note all the CorrectAnalog stuff can be removed as you aren't using it. You have it both included and copied in.
    Regards
    TK
    http://dynomotion.com
    Dobro's Avatar
    Jul 2017
    Tom, thank you so much for reply!
    This configuration was working properly about two month ago. But now something wrong.
    I use Kmotion CNC 4.34j, my configuration file:
    Code:
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    // Defines axis 0, 1, 2 as simple step dir outputs
    // enables them
    // sets them as an xyz coordinate system for GCode
    int main()
    	InitAux();
    	AddKonnect_Aux0(0,&VirtualBits,VirtualBitsEx);
    	ch0->InputMode=NO_INPUT_MODE;
    	ch0->OutputMode=STEP_DIR_MODE;
    	ch0->Vel=60000;
    	ch0->Accel=60000;
    	ch0->Jerk=60000;
    	ch0->P=0;
    	ch0->I=0.01;
    	ch0->D=0;
    	ch0->FFAccel=0;
    	ch0->FFVel=0;
    	ch0->MaxI=200;
    	ch0->MaxErr=1e+006;
    	ch0->MaxOutput=200;
    	ch0->DeadBandGain=1;
    	ch0->DeadBandRange=0;
    	ch0->InputChan0=0;
    	ch0->InputChan1=0;
    	ch0->OutputChan0=0;
    	ch0->OutputChan1=0;
    	ch0->MasterAxis=-1;
    	ch0->LimitSwitchOptions=0x101;
    	ch0->LimitSwitchNegBit=1024;
    	ch0->LimitSwitchPosBit=0;
    	ch0->SoftLimitPos=277700;
    	ch0->SoftLimitNeg=-277700;
    	ch0->InputGain0=1;
    	ch0->InputGain1=1;
    	ch0->InputOffset0=0;
    	ch0->InputOffset1=0;
    	ch0->OutputGain=-1;
    	ch0->OutputOffset=0;
    	ch0->SlaveGain=1;
    	ch0->BacklashMode=BACKLASH_OFF;
    	ch0->BacklashAmount=0;
    	ch0->BacklashRate=0;
    	ch0->invDistPerCycle=1;
    	ch0->Lead=0;
    	ch0->MaxFollowingError=1000000000;
    	ch0->StepperAmplitude=20;
    	ch0->iir[0].B0=1;
    	ch0->iir[0].B1=0;
    	ch0->iir[0].B2=0;
    	ch0->iir[0].A1=0;
    	ch0->iir[0].A2=0;
    	ch0->iir[1].B0=1;
    	ch0->iir[1].B1=0;
    	ch0->iir[1].B2=0;
    	ch0->iir[1].A1=0;
    	ch0->iir[1].A2=0;
    	ch0->iir[2].B0=0.000769;
    	ch0->iir[2].B1=0.001538;
    	ch0->iir[2].B2=0.000769;
    	ch0->iir[2].A1=1.92081;
    	ch0->iir[2].A2=-0.923885;
        EnableAxisDest(0,0);
    	ch1->InputMode=NO_INPUT_MODE;
    	ch1->OutputMode=STEP_DIR_MODE;
    	ch1->Vel=160000;
    	ch1->Accel=160000;
    	ch1->Jerk=160000;
    	ch1->P=0;
    	ch1->I=0.01;
    	ch1->D=0;
    	ch1->FFAccel=0;
    	ch1->FFVel=0;
    	ch1->MaxI=200;
    	ch1->MaxErr=1e+006;
    	ch1->MaxOutput=200;
    	ch1->DeadBandGain=1;
    	ch1->DeadBandRange=0;
    	ch1->InputChan0=1;
    	ch1->InputChan1=0;
    	ch1->OutputChan0=1;
    	ch1->OutputChan1=0;
    	ch1->MasterAxis=-1;
    	ch1->LimitSwitchOptions=0x101;
    	ch1->LimitSwitchNegBit=1025;
    	ch1->LimitSwitchPosBit=0;
    	ch1->SoftLimitPos=198890;
    	ch1->SoftLimitNeg=-198890;
    	ch1->InputGain0=1;
    	ch1->InputGain1=1;
    	ch1->InputOffset0=0;
    	ch1->InputOffset1=0;
    	ch1->OutputGain=-1;
    	ch1->OutputOffset=0;
    	ch1->SlaveGain=1;
    	ch1->BacklashMode=BACKLASH_OFF;
    	ch1->BacklashAmount=0;
    	ch1->BacklashRate=0;
    	ch1->invDistPerCycle=1;
    	ch1->Lead=0;
    	ch1->MaxFollowingError=1000000000;
    	ch1->StepperAmplitude=20;
    	ch1->iir[0].B0=1;
    	ch1->iir[0].B1=0;
    	ch1->iir[0].B2=0;
    	ch1->iir[0].A1=0;
    	ch1->iir[0].A2=0;
    	ch1->iir[1].B0=1;
    	ch1->iir[1].B1=0;
    	ch1->iir[1].B2=0;
    	ch1->iir[1].A1=0;
    	ch1->iir[1].A2=0;
    	ch1->iir[2].B0=0.000769;
    	ch1->iir[2].B1=0.001538;
    	ch1->iir[2].B2=0.000769;
    	ch1->iir[2].A1=1.92081;
    	ch1->iir[2].A2=-0.923885;
        EnableAxisDest(1,0);
    	ch2->InputMode=NO_INPUT_MODE;
    	ch2->OutputMode=STEP_DIR_MODE;
    	ch2->Vel=60000;
    	ch2->Accel=60000;
    	ch2->Jerk=60000;
    	ch2->P=0;
    	ch2->I=0.01;
    	ch2->D=0;
    	ch2->FFAccel=0;
    	ch2->FFVel=0;
    	ch2->MaxI=200;
    	ch2->MaxErr=1e+006;
    	ch2->MaxOutput=200;
    	ch2->DeadBandGain=1;
    	ch2->DeadBandRange=0;
    	ch2->InputChan0=2;
    	ch2->InputChan1=0;
    	ch2->OutputChan0=2;
    	ch2->OutputChan1=0;
    	ch2->MasterAxis=-1;
    	ch2->LimitSwitchOptions=0x101;
    	ch2->LimitSwitchNegBit=1026;
    	ch2->LimitSwitchPosBit=0;
    	ch2->SoftLimitPos=55290;
    	ch2->SoftLimitNeg=-55290;
    	ch2->InputGain0=1;
    	ch2->InputGain1=1;
    	ch2->InputOffset0=0;
    	ch2->InputOffset1=0;
    	ch2->OutputGain=-1;
    	ch2->OutputOffset=0;
    	ch2->SlaveGain=1;
    	ch2->BacklashMode=BACKLASH_OFF;
    	ch2->BacklashAmount=0;
    	ch2->BacklashRate=0;
    	ch2->invDistPerCycle=1;
    	ch2->Lead=0;
    	ch2->MaxFollowingError=1000000000;
    	ch2->StepperAmplitude=20;
    	ch2->iir[0].B0=1;
    	ch2->iir[0].B1=0;
    	ch2->iir[0].B2=0;
    	ch2->iir[0].A1=0;
    	ch2->iir[0].A2=0;
    	ch2->iir[1].B0=1;
    	ch2->iir[1].B1=0;
    	ch2->iir[1].B2=0;
    	ch2->iir[1].A1=0;
    	ch2->iir[1].A2=0;
    	ch2->iir[2].B0=0.000769;
    	ch2->iir[2].B1=0.001538;
    	ch2->iir[2].B2=0.000769;
    	ch2->iir[2].A1=1.92081;
    	ch2->iir[2].A2=-0.923885;
    	EnableAxisDest(2,0);
    	DefineCoordSystem(0,1,2,-1);
       // return 0;
     int Answer;
          for (;;) // loop forever
    if (ReadBit(1027)||ReadBit(1028)||ReadBit(1029))  // Watch an external input switch
             StopCoordinatedMotion();  //feedhold
             ClearBit(48); //stop shpindle and pump
             Answer = MsgBox("ALARM_AXIS",MB_OK|MB_ICONEXCLAMATION); //message ALARM_AXIS
                if (Answer == IDOK)
                ClearBit(4);
                ClearBit(5);
                ClearBit(6);
                Delay_sec(3);
                SetBit(4);
                SetBit(5);
                SetBit(6);
             Answer = MsgBox("AXIS_RESTART",MB_OK|MB_ICONEXCLAMATION); //message AXIS_RESTART
        return 0;
    When I turned off my frequency converter all working fine, until I try to turn on, after that I have Kflop disconnecting.
    May 2006
    Hi Dobro,
    So I assume you have the S Action configured without wait otherwise it would never work.
    If you have KFLOP disconnecting only with Spindle Power on and never otherwise then it is likely noise from the Spindle.
    Anything change? Is the Spindle body Earth Grounded? Do you have a reasonably short USB cable? Does the USB Cable have a good shield (shell to shell resistance less than 1 ohm)? Does the USB cable have ferrite rings? Is Spindle wiring close to the USB cable?
    You might also want to determine if KFLOP is re-booting (LEDs flash) due to power glitch or other. That would also cause a USB Disconnect.
    Regards
    TK
