Ini file for inch
Results 1 to 2 of 2
Thread: Ini file for inch
    May 2017
    Default Ini file for inch
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Ini file for inch
    Hi Joe,
    I assume you mean to have KMotionCNC default to Inches mode on startup? Default settings for the Interpreter can be configured in the Setup file. See:
    Tool Setup Screen Files
    There should also be an example Setup file called INCHES.set with this change that you can select.
    HTH
    Regards
    TK
    http://dynomotion.com
Ini file for inch
Ini file for inch
