Need Help! I need to calculate Step per for ROTARY AXIS
Results 1 to 4 of 4
Thread: I need to calculate Step per for ROTARY AXIS
    Jan 2012
    Question I need to calculate Step per for ROTARY AXIS
    Hi everyone, I need to calculate step per for the 4th axis but I`m very confused with all this numbers
    How can I do that this is the information that I have I would appreciate if you include step by step to learn how to calculate this
    DC Servo Motor Model DCM50207D-1000 (they say that 1000 are 1000 lines)
    V 30.3
    N.M 0.35
    r/m : 2900
    TWO PULLEYS
    Small Pulley Diameter 31.4 - 20 Teeh on shaft of the motor
    large Pulley Diameter 94 - 60 Teeh on shaft of the Chuck
    I would appreciate all your help guys and have a wonderful 2018
    Ivano
    Mar 2003
    Default Re: I need to calculate Step per for ROTARY AXIS
    1000 *3 = 1000
    But it may be 4000*3 = 12000
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Ivano,
    It would be helpful to know what kind of system you have and what software you are using.
    But most rotary axes use units of degrees so the answer might be:
    1000 lines/rev x (4 counts/line) x 3 x (1rev/360degrees) = 33.33333333 counts/degree
    You might just try a number and if it doesn't work measure the factor you are off by and divide the number by that factor.
    HTH
    Regards
    TK
    http://dynomotion.com
    Mar 2003
    Oops, I forgot to divide by360°.
