Need Help! 4th Axis: Using soft limits to prevent table crashes?
Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: 4th Axis: Using soft limits to prevent table crashes?
    Feb 2008
    Default 4th Axis: Using soft limits to prevent table crashes?
    Hi Tom,
    We have fabricated the 4th axis for our machine and are about to start programming it and testing it out. Both ends of the 4th axis (Motor/Part Chuck and the Tail stock) are tall and will make contact with the spindle/cutter at full Z height if they drive over top of them. Needless to say I’m very fearful of a crash occurring as I learn what I’m doing.
    I was reading a bit and saw the soft limits, I understand how they work in the context of the overall working envelope, to manually get you back in a safe zone before hitting the hard limits. But I was wondering if you can apply 2 “no fly zones” in terms of X&Y rectangles placed on the X&Y coordinates so that if the machine were to drive into these areas it stops and waits for operator intervention to move it safely out of the way preventing a crash.
    I was trying to think of how that could be executed, can there be something added to the initialization file that reads a table of the user inputted X&Y machine coordinates for the no fly zone and applies them as soft limits?
    We will be moving the tail stock and head stock around the table based on 4th axis part size so having a table file we input would be the best way to keep the machine aware of where the obstacle are located on the table and when the 4th axis is not present we can remove the no fly zones from the program table and the machine operates like usual.
    Any advice or suggestions would be greatly appreciated.
    Thanks,
    Dan
    4th Axis: Using soft limits to prevent table crashes?-4th-axis-soft-limits-jpg
    May 2012
    canada
    Default Re: 4th Axis: Using soft limits to prevent table crashes?
    You could add a check to your forever loop that would look for X and Y position being in a certain range and if they both were you could get it to stop, E-stop or whatever you wanted. You would need to know the start and end of the two zones for each axis.
    Might be more practical to just really watch things closely for the first part. I used to do alot of 4th axis stuff at my last job, its not too bad after a while. One good piece of advice i can give you is to take the 4th axis off when doing non 4th axis work. Even if you think you have enough room lol.
    Dec 2015
    Can you model the fixture in your CAM?
    Feb 2008
    Yeah i found some soft limits C code in the Kmotion folder, I've made some code that i will try. I'll see if my coding skills have gotten better.
    And yes we have a small vacuum table that sits on the bed and it always seems to be in the way. We need to make more storage around the shop.
    Feb 2008
    Quote Originally Posted by CL_MotoTech View Post
    No I don't think so. I'll have to look into what fusion can do.
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Dan,
    I think a simple test for an invalid region should be pretty simple. Just a few "if" conditions. But if your machine requires a significant distance to stop, and you can't simply increase your invalid regions to accommodate this, then it may be more complicated.
    Regards
    TK
    http://dynomotion.com
  7. #7
    Feb 2008
    Quote Originally Posted by TomKerekes View Post
    Hi Dan,
    Regards
    Ok thanks Tom, the only thing I'm a little fuzzy on right now is making sure the coordinate system is correct. All c code is based off of counts right? So I will have to multiply my distances (in inches) by the counts/inch for that axis correct? Also I think that since I'll be using machine coordinates and not part zero coordinate system I don't have any trickery there to deal with right?
  8. #8
    May 2006
    Hi Dan,
    That all sounds correct. Although it might be better to divide by the resolution in counts/inch to convert the current position to inches, then do all the checks in inches.
    Regards
    TK
  9. #9
    Feb 2008
    Hi Tom,
    I got the soft limits to work in principle. Every time i enter the 2 zones from any direction all 3 axis get disabled which is good.
    I'd like to make it so that i can back off of the limit and keep going without having to re-initialise and home and start from the beginning. I read your Rev2 for soft limits which i think dose this but im not sure how to apply the function when im dealing with 4 conditions that need to be met.
    I've attached my code below for you to see. I made 2 arbitrary box sizes for testing. Called "Head" for Head stock and "Tail" for Tail stock
    Thanks Dan
    Attached Files Attached Files
  10. #10
    May 2006
    Hi Dan,
    You would need to come up with some strategy for what you want to do?
    The simplest would be to add an override button that you might use to disable the no-fly zones. Of course the Operator could then still crash the spindle.
    Otherwise you might determine the direction that would move out of the limits in the shortest direction and disallow motion in any other direction.
    Or save the direction of motion that each axis was moving in when "Inlimit" was first detected. Then only allow motion for any axis in the opposite direction.
    Regards
    TK
  11. #11
    Feb 2008
    Hi Tom,
    I think the first approach is fine. (Button to disable the no fly zone) How do I include that into the C code?
    I see that there are 2 Soft Limit files in the example C code Folder. Does the Rev 2 file include the back up approach for a simple soft limit working envelope?
    I also realised that this soft limits code doesn't work when i'm doing a tool change (M6 C Program) or when homing the machine (Homing C Program). How do I keep this program active when other C programs are being initiated?
    Sorry lots of questions all at once. I've included a picture of the new 4th axis set up we built. We were making a Christmas tree out of a 4" cedar post and when we went to run the finishing 3d tool path the spindle went up in the Z and crashed. It took out the Viper drive and needs to be shipped away for repair. So i found another application for soft limits i didn't think i needed
    That's an 8" Chuck btw. Coke can for scale.
    Attached Thumbnails Attached Thumbnails 4th Axis: Using soft limits to prevent table crashes?-dsc09659-large-jpg   4th Axis: Using soft limits to prevent table crashes?-dsc09668-large-jpg   4th Axis: Using soft limits to prevent table crashes?-dsc09685-large-jpg   4th Axis: Using soft limits to prevent table crashes?-dsc09686-large-jpg
    4th Axis: Using soft limits to prevent table crashes?-dsc09687-large-jpg   4th Axis: Using soft limits to prevent table crashes?-dsc09689-large-jpg
  12. #12
    Jun 2004
    Scotland
    That V2 file should let you back out of limits, however it's still disabling things.
    What I think you're wanting to do, is activate a feedhold when you enter your no-fly zones.
    Then as Tom has said, you want some way to track/test how you ended up in the no fly zone, then only allow movement in the safest direction.
    However, I suspect that provided things stop when you hit a no-fly zone, you'd be happy enough to simply disable the no-fly zones, move to a safe point, then re-enable the no-fly zones?
