But why does the machine stop? Is it an eStop? Is the C axis jamming?
Cheers
Roger
Hello Guys,
Lately i have been facing a problem with the 5 - Axis machine that I am working on. The rotation of C - Axis stops at a particular code.
For Example:
N220 X0.267 Y-19.998 Z49.809 C0.7653
N225 C0.7636........................................... ................................[MACHINE HALTS AT THIS CODE, I CLICK STOP AND THEN START THE CYCLE FROM THIS LINE]
N230 X0.134 Y-20 Z49.866 C0.3826
N235 X0.133 C0.3809
N240 X-0.001 Z49.885 C-0.0017
N245 C-0.0035............................................ .............................[WORKS PERFECTLY]
N250 X-0.135 Z49.865 C-0.3861
N255 C-0.3878................................... ..................................... [MACHINE HALTS AT THIS CODE AGAIN, I CLICK STOP AND THEN START THE CYCLE FROM THIS LINE]
SO ON
When i simulate the same G-Codes in K-MotionCNC it work fine without any pause. I tried to run the same G-Codes on the machine multiple times and each time it stops at that exact line.
Has anyone faced a similar problem with their machine.
Your suggestions on this topic will be helpful to overcome the hurdle.
Thank you in advance
Vignesh M
Regards
Amit Kumar
Cheers
Roger
Any chance there is a soft limit that wont allow the negative position?
Gary Campbell GCnC Control
Servo Control & ATC Retrofits
Looks to me like it may need an x,y or z axis specified in each line, and doesn't like a C axis only line? Assuming you're running in absolute mode, just copy the previous X dimension and paste it onto the line with only a C axis move and see if that helps? You show one example of a C axis only line that works fine though, so maybe not.
Hi Amit/Vignesh,
This looks to be a bug in our code. We've been able to reproduce the problem but we will need time to come up with a fix.
So far it seems to be related to combining pure angular moves and mixed xyz+angular moves and rounding/smoothing calculations with some numerical error that results in a move of like 1e-12 inches at a feedrate of 1e-18 ips that would take hours to complete.
Regards
Regards
TK http://dynomotion.com
Hi Amit/Vignesh,
Please try this patch. It is compatible with Test Version 4.34j. Copy the library to the \KMotion\Release folder
http://dynomotion.com/Software/Patch...nterpreter.dll
This should no longer attempt to smooth the segment of pure angle with a non-pure angle segment (which shouldn't make sense).
Modified source files if needed are located here:
Index of /Software/Patch/FixTPMixPureAngleNonPureAngle_V4.34j
Please let us know if it resolves the problem.
Regards
Regards
