Hi Amit,
Any input can be used.
See the ExternalButtons.c example.
Regards
Hi Everyone,
I am using Kflop Controller. Now i have a requirement of adding 4 external buttons to same controller. And i can't find any support on that.
I am planning to connect Emergency stop, Feed Hold, Cycle Start, Cycle Stop Buttons.
So on which pin i have to connect these buttons on KFLOP or KANALOG. ?
And after connection which C program to run for make external buttons work ?.
it also helps others to make proper wiring on KFLOP Controller.
Waiting for Positive response.
Thank You
Amit Kumar
- Need Help!- How to connect external board to kflop?
- KFLOP/Kanalog set up
- KFlop Kanalog and DMM
- New Machine Build- KFlop/Kanalog/Mach3
- Retrofit old Cnc with kflop-kanalog
Regards
Amit Kumar
Hi Amit,
Regards
Regards
TK http://dynomotion.com
Hi Tom,
ok i connected my all 4 buttons to IO Bit 26, 27, 28, 29.Any input can be used.
I have seen this ExternalButtons.c example. But how can i initialize this file. ?See the ExternalButtons.c example.
Should i include same in INIT file or i have to run it again and again.?
or how can i include this c program into my INIT program. ?
Thank You
Amit Kumar
Regards
Amit Kumar
Hi Amit,
Yes after it is working you can merge the program with your Init C Program.
See:
KFLOP C Programs - Dynomotion
and
Regards
Regards
