Build Thread Tree325 Retrofit Started - Page 16
Page 16 of 16 FirstFirst ... 613141516
Results 181 to 185 of 185
Thread: Tree325 Retrofit Started
  1. #181
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Tree325 Retrofit Started
    Some thoughts:
    Personally I would not connect the limit switch override to the controller. To me, I want the limits to kill movement regardless of how I've programmed the controller, as if it was connected to the controller, you have to be fully aware that that output was only active when needed, otherwise you're risking running into the hard stops at full power. With it on a physical switch, should anything go wrong, movement gets killed, and should anything go wrong during recovery, you just need to release the switch.
    I think this is all 100% correct. If the controller is miss programmed, defective, has a bug, or has the wrong program loaded the machine could crash because the controller has the ability to bypass limits.
    On the other hand, with an override pushbutton the Operator could then crash the machine which would theoretically not be possible if the Controller has control of the overrride and is working properly. So I think it boils down to who you trust more. Your Controller, configuration, and software vs the Operator.
    Its up to PeterTheWolf to decide how he would like his machine to work. I'd recommend keeping the Operator Pushbutton at least until you think all the bugs are worked out.
    Also it seems the original system doesn't have any Home sensors. I see the controller seemed to have Home sensor inputs. But those are wired high. So in order to Home automatically using the Limit Switches the Controller would need control of the override.
    Conversely the controller currently doesn't have any way to enable/disable the Amplifiers either (the thing m_c is referring to). Say the Operator pushes the "Stop" button on the Computer Screen and we wish to EStop and disable everything. Or KFLOP detects a runaway axis. Right now the best KFLOP can do is command zero speed to the Amplifiers. So we might add another "switch" in the enable circuit so KFLOP also has a say on whether things are enabled or not.
    Regards
    TK
    http://dynomotion.com
  2. #182
    Registered PeterTheWolf's Avatar
    Aug 2008
    Quote Originally Posted by m_c View Post
    Personally I would not connect the limit switch override to the controller. ...
    Quote Originally Posted by TomKerekes View Post
    ...... If the controller is miss programmed, defective, has a bug, or has the wrong program loaded the machine could crash because the controller has the ability to bypass limits.
    I think it is best for me not to connect the hardware limit switches to KFLOP at this time. Since there is too much I am not confident with on the connecting of this and the C-code programming involved.
    I'd recommend keeping the Operator Push Button at least until you think all the bugs are worked out.
    I will keep this manual override connected for careful use for now.
    Those look like good values. But if KFLOP was really set to those values then you should get a following error when the axis hits the limit switch and stops moving. Something isn't right. Maybe you didn't merge those settings into your Initialization C Program? Or didn't execute the C Program? Or executed the wrong Program? Please post your final Initialization C Program. Also verify the Init button is configured to the that program. You can also "Upload" an axis to KMotion.exe to see what the Following Errors are currently set at.
    I am pretty sure I have the Initialization C Program correct and set for the INIT button in KMotionCNC.
    Here is my INIT FIle.
    Tool Set-Up Dialog Box:
    Tree325 Retrofit Started-button_setup-jpg
    There are no homing sensors on this machine. From what I understand, there was a reference position of each axis that was manually set upon each power-up of the machine.
    I am now looking into getting (3X) proximity switches to mount and connect for a homing position on each axis.
    This home position should then give me an accurate place to set the counts on the soft-limits.
    Can I please get some advice on these sensors?
    This is the sensor I plan to get: PD1-AD-F3
    Also some advice at connecting this to Kanalog.
    Correct me if I am wrong but I am thinking I would connect one sensor like this:
    1.) The Brown (#1) wire would get connect to a 24VDC source.
    2.) The Black (#4) wire would get connect to Kanalog JP15 (Pin 15)
    3.) The Blue (#3) wire would get connected to Kanalog JP15 (Pin 16)
    Then I would need to use C-Program "SimpleHome3Axis.c".
    Question:
    1.) Do I need to add this C-Program to the "INIT" C-Program to test? Or is there a way to test it before adding it to the "INIT" C-program?
    2.) When this "SimpleHome3Axis.c" program runs and the Proximity switch closes the the axis is disabled and then the it "Zero(2); // Zero the position" .... is this "Zero(xx)" what sets the counts on the given axis to 0.0?
    3.) Then I can manually move the given axis to the a position just before it hits the hardware limit ... look at my counts in Kmotion and then use that the software limit setting?
    Sorry if these are elementary questions, I may have a few until I get a better understanding on setting up these switches.
    J325 Quick Links:
    Machine
    Existing Machine Schematics
    Electronic Cabinet-Right Side
    Electronic Cabinet-Back SIde
    Existing Drive Board SD1525-10
    J325 Servo Drive-SD1525 Manual
    3-Phase Rotary Convert Used
    RickB's J325 Retrofit Wiring
    KFLOP 5VDC/15Watt/3A Power Supply
    KANALOG Mounted & Connected
    Kmotion - Axis Encoder Manual Test of Position via Manual Movement
    Kanalog-Encoder Voltage High/Low Checks & 1KOhm Resister
    Kmotion Configuration Screens "RUN-AWAY"
    Tree Journeyman 325 Designed Specs.
    Tree Journeyman 325 Axis-Tension Frequency Settings
    Final Axis Tuned Error Parameters
  3. #183
    May 2006
    Hi PeterTheWolf,
    It seems clear the Maximum Following Errors are all set incorrectly. Did you look at your file? I see lines of:
    ch0->MaxFollowingError=10000000;
    Set to reasonable values and try again.
    I think those sensors should work. You have the choice of NPN (work like a switch to GND) or PNP (work like a switch from + supply). Either one will work with Kanalog Opto Inputs. The wiring you describe doesn't list a GND connection back to the 24V Supply. You will need GND connected to the Blue wire. Because you are connecting Kanalog to GND you would need the PNP type. Its more common to use NPN type so I would purchase NPN and connect the load (Kanalog) to the +24V instead.
    Question:
    No you probably don't want to merge homing into your INIT C Program unless you desire to automatically Home every time you initialize. More common is to make a separate program (that runs in a different Thread) and assign it to a HOME button that can be pushed whenever you wish to home. In general any program can be tested out and debugged separately by running it in a separate Thread in KMotion.exe and then after it is working you can decide to merge it with other Programs or not.
    Yes. It will set the Raw Machine coordinates to 0. Depending on GCode Offsets the DROs may or may not go to zero.
    Yes. Note that on Power up the machine coordinates will not be necessarily aligned to your machine so it doesn't really make sense to use soft limits until after the machine has been Homed. So when soft limits are used normally they are disabled (set to large values) by the Homing routine and restored after the Homing has successfully completed.
    HTH
    Regards
    TK
  4. #184
    Aug 2008
    Hi PeterTheWolf,
    Thanks Tom ... I am sorry for my ignorance ... when I changed the "Input Channels" & "Output Channels" from "1"to "-1" to reverse the motion direction for correct movement on the axis on NC-code I some how did not pay attention to the file I was editing.
    Now I am seeing what you explained earlier on the hardware limits ... in that when I hit the hardware limits the amp power is cut off and then I can use the momentary switch to apply power back to the amp without a scary movement when I hit the "INIT" button and then move off the hardware limit and reinitialize KmotionCNC. It is indeed functioning as designed.
    I will purchase the NPN as advised .... thanks for taking the time to explain this to me.
    I will get these proximity sensors and try my hand at getting the X-axis working correctly (first) with the C-Program "SimpleHome3Axis.c" in a new thread for testing.
    I really appreciate your patience and taking the time to explain the elementary.
    J325 Quick Links:
    Machine
  5. #185
    May 2006
    Hi PeterTheWolf,
    No worries. Just don't let it happen again
    Regards
    TK
