New Machine Build Jog speed and acceleration
Results 1 to 2 of 2
Thread: Jog speed and acceleration
    May 2017
    Default Jog speed and acceleration
    New build first time building a machine. Connected a stepper motor to my gantry for first time. Tested using the jog button\ arrows in kmotion works great. When I do a move command with a .1000 movement works, .2000 movement works, .3000 movement to fast or acceleration to much, stepper motor stalls.
    What is the speed and acceleration of the jog buttons and how do I set the max speed and acceleration? I am not sure but think that is causing the stall.
    I also have to figure out the setting for steps per inch i'm using a 5mms ballscrew.
    Joe
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Jog speed and acceleration
    Hi Joe,
    You should configure, test, and determine your axes limits using KMotion.exe before running KMotionCNC. See:
    Dynomotion
    Regarding axis resolution, it would also depend on Stepper Drivers, gearing, etc. See:
    Dynomotion
    HTH
    Regards
    TK
    http://dynomotion.com
