Need Help! How to setup kinematics RTCP in KmotionCNC - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 51 of 51
Thread: How to setup kinematics RTCP in KmotionCNC
  1. #49
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: How to setup kinematics RTCP in KmotionCNC
    Hi Kumar,
    Great. Thanks for posting back.
    If you find time please try to troubleshoot why you weren't compiling the code. Some things I sometimes do is to put an intentional error in the file that I'm changing. If there isn't an error when compiling I know I'm changing the wrong file. Also check the timestamp on the executable to see that it has actually been re-built.
    Regards
    TK
    http://dynomotion.com
  2. #50
    Gold Member amitkumar171's Avatar
    Aug 2017
    India
    Quote Originally Posted by TomKerekes View Post
    Hi Kumar,
    Regards
    Hi tom,
    Actually timestamp on the Kmotioncnc.exe file was not changing. When i was trying to compile the code earlier but after you compiled timestamp was changing. How is that even possible.?
    AMIT KUMAR
    Sent from my Lenovo K50a40 using Tapatalk
    Regards
    Amit Kumar
  3. #51
    May 2006
    Hi Amit,
    Were you compiling the Libraries (BuildAllLibs.sln) or the Examples (BuildExamples.sln) ? KMotionCNC is an example Application not a library. The Kinematics is part of the Libraries.
    Were you looking at the correct Debug or Release directory depending on whether you were building the Debug or Release Configuration?
    Was the build successful? Did the build compile the file?
    Regards
    TK
