Kanalog control of altavit31 vfd
Results 1 to 3 of 3
Thread: Kanalog control of altavit31 vfd
    Apr 2013
    Default Kanalog control of altavit31 vfd
    Ativar31 has a 24 volt control for forward/reverse; can this be directly controlled by one of the FETs on the kanalog or must it be done indirectly with an SSR or relay(plus diode)?
    Also 0-10 volts input from DAC should control speed (closed loop via quadature input)?
    This seems correct just don't want to fry the board
    Thanks in advance for insight.
    Feb 2006
    Default Re: Kanalog control of altavit31 vfd
    You'll have much more luck asking this question on the Dynomotion forum. I'd be amazed if there were more than two people here who even know what a KAnalog is...
    Regards,
    Ray L.
    Jun 2005
    Dynomotion team monitors this site on a regular basis. Tom will answer your question. Look at the specs on the FET on the Kanalog page of their site, clear safer to use SSR, so you won't have a chance to damage the Kanalog.
    Tom is the expert he has all kinds of experience.
    Russ
