Snapamp set up
Results 1 to 3 of 3
Thread: Snapamp set up
    May 2013
    Usa
    Default Snapamp set up
    I am setting up a snapamp , and have noticed that the one I have has changed since the on line manual was posted.
    the ground cable on the snap amp goes to chassis or kflop?
    do I use a jumper on jp5 if I am using only 1 board , manual only mentions 2 board layout , also what does the jumper do ?
    Does snapamp get 5 volts to run from kflop jp4 to jp6 connection?
    I have checked out the manual on line and the wiki , is there another source for info ?
    Member TomKerekes's Avatar
    May 2006
    Default Re: Snapamp set up
    Hi Gregore,
    Regarding:
    KFLOP
    Manual states:
    JP5 Jumper installed configures a SnapAmp as the 2nd SnapAmp.
    So do not install Jumper JP5 on the first or only SnapAmp.
    Yes. As the manual states: JP6 is for Communication and Logic power.
    There are also Forum and Yahoo Group Posts.
    Regards
    Regards
    TK http://dynomotion.com
    May 2013
    Usa
    Thanks ,
    very slowly this is starting to make some sense ....... there is soooo much to learn when you are coming from just blindly running a CNC machine with no clue as to anything that goes on behind the curtain .
Snapamp set up
Snapamp set up
