Encoder wiring
Results 1 to 14 of 14
Thread: Encoder wiring
    May 2013
    Usa
    Default Encoder wiring
    I just purchased a harmonic drive fha -c mini e200.
    It has 45 wires for the incremental Encoder
    The manual has the 5 wires as the following .
    +5
    0v
    Sd
    Sd ( with a line on top )
    Shield
    Is there anyone who can help me figure out how to wire it up to the snapamp ?
    Here is a link to the manual if that helps , chapter 1/14
    http://www.harmonicdrive.net/_hd/con...al)%20100V.pdf
    And if anyone has the patience to explain what the wires actual do I would certainly be willing to learn
    Many thanks
    Member TomKerekes's Avatar
    May 2006
    Default Re: Encoder wiring
    Hi Gregore,
    45 wires??
    That doesn't look like incremental encoder signals. Are you sure you have the right manual?
    I found this.
    http://www.harmonicdrive.net/_hd/con...c100v-200v.pdf
    1-15-1 shows a more typical A B Z type of single ended incremental encoder.
    Regards
    Regards
    TK http://dynomotion.com
    May 2013
    Usa
    Sorry typo , should be 5 wires
    And yes that is the same company but the USA models is with 14 wires , the Asian model has only 5 wires like mine , I posted a link to the manual for the one I have
    It is hard look things up when your a newbie as a lot of websites that explain things assume you know enough to understand them , and it is difficult to look things up because instructions use abbreviations, and google is bad with uncommon technical abbreviations.
    Thanks for the quick reply
    Dec 2003
    Quote Originally Posted by Gregore View Post
    I
    +5
    0v
    Sd
    Shield
    Many thanks
    Sd = A channel
    /Sd = B channel
    shield
    No marker pulse on this non-differential type encoder.
    +5 and 0v supply
    Not a standard way of indication.
    May 2013
    Usa
    So that means that it has no Z wire , so no homing markers ?
    If so I guess it is a paper weight , as it will not do what I need it to do ...... good thing it was cheap
    Also I noticed it is an AC 100volt servo , Can snapamp even handle that ?
    May 2006
    Hi Gregore,
    I believe that is true.
    SnapAmp is limited to an 80V supply. It might still work but max speed would be limited.
    Regards
    Regards
  7. #7
    Feb 2008
    An encoder with just power and SD, /SD is pretty much guaranteed to be a serial absolute encoder...
  8. #8
    May 2013
    Usa
    Thanks every one
  9. #9
    May 2006
    Hi Gregore,
    I tend to agree with PCW_MESA. With a scope or even voltmeter you should be able to tell the difference. SnapAmp will only work with an incremental encoder.
    Regards
    Regards
  10. #10
    May 2013
    Usa
    I intend to order the us200 version which I know is an incremental encoder . My friend already set a bunch up on a snapamp last year .
    But the lead time is 6 months and $2500 each
    They do list this as an incremental encoder though
    How do I go about checking it ? I know it has a glass disc inside with stripes all the way around .
    Encoder wiring-img_5675-jpg
  11. #11
    May 2013
    Usa
    I looked under a microscope and the 2 stripes on the glass are really hundreds of segmented lines , I think that sounds more like a an absolute encoder ????
  12. #12
    May 2006
    Hi Gregore,
    Well the actual encoder is likely to be absolute for purposes of commutating the motor and such. But based on circuitry it could either output incremental quadrature or serial absolute to the outside world. Do you have an oscilloscope?
    If it is differential serial absolute (very likely) I would expect the SD and \SD to be complements of one another (not quadrature - always opposite levels). I'd expect to see a serial stream of data maybe 20 bits long shifting out periodically.
    If it is single ended incremental quadrature the SD and \SD would be quadrature. They would toggle with 50% duty cycles 90 degrees out of phase when moving and so not always be opposite levels.
    Regards
    Regards
  13. #13
    Dec 2003
    Quote Originally Posted by PCW_MESA View Post
    Now you mention it. SD and /SD would make more sense for a serial encoder, SD = serial data and the / would = the RS485 complement.
    Most are absolute.
    But generally practically all encoders start off as sin/cos encoders at the root detection level, even simple square wave quadrature, in these, the sin/cos is simply squared up.
    With others such as absolute, use the sin/cos to a 16bit A/D also the sin/cos is used to calculate the co-tangent result.
    A precise converter for resolvers and sinusoidal encoders based on a novel ratiometric technique - IEEE Xplore Document
    There are some with 8 bit 10bit binary.
    May 2013
    Usa
    I have a friend with an oscilliscope
    I will have to do a little reading to make sure I understand all that was said before I hook it up to the scope , but I am sure my friend will understand some of it too.
Encoder wiring
Encoder wiring
