Hi Gilad,
What kind of Servos do you have? Do you have Amplifiers/Drives? What kind of encoders do you have? Differential or single ended?i need to control
- 4 movement servos and one spindle servo (all with encoders feedback).
- some relays and solenoids
Winford.com sells simple breakout boards for cables such as:is there any simple breakout board that provides simple screw terminals to all IO?
2x13 0.1" Header (26 position IDC ribbon connector) Breakout Board with Screw Terminals - Winford Engineering
They also sell simple Relay boards that can be driven with LVTTL signals:maybe some relays?
Relay Board: TTL Logic Level Inputs, 2 SPDT 15A Relays - Winford Engineering
Yes you can. Those are only suggested Inputs for Limits if they are available. Home/Limits are handled in software and can be configured to any Input.i don't understand the difference between general purpose IO pins and ones designated to a specific task. like on JP7 - you can either have a step/dir axis or home switches? can't you have both?
I don't see any reason it shouldn't work.regarding the PC itself, i'm thinking of coupling Kflop with Lattepanda's single board windows 10 PC, it's a quad core Intel atom with 4 gigs of ram, any reason why it shouldn't work?
Regards
