Need Help! kmotioncnc jogging in X but not YZ
Results 1 to 7 of 7
Thread: kmotioncnc jogging in X but not YZ
    Apr 2013
    Default kmotioncnc jogging in X but not YZ
    I have moved through the steps of physical connection and kmotion c code generation for KFLOP + KANALOG on a Millstar III (Glentek servo and Mitutoyo glass scale) equipped Bridgeport clone. Have setup the init.c (as init_mill_stariii.c).
    F9 key loads the init file I can jog X left and right ---Super!!!
    When next trying Y or Z I get nothing when I try to go back to X I get nothing.
    The limit switches have not been tripped; Amps aren't stopped; and I can move the axes however I wish using KMOTION.
    I believe the axes are enabled (as 0,1,2) and are run obviously as DAC servos.
    What am I missing
    Thanks in Advance (and lots more, of course, as the answers pour in !!)
    Owen
    Attached Files Attached Files
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: kmotioncnc jogging in X but not YZ
    Hi Owen,
    Post your C initialization file (as a .txt file)
    Regards
    TK
    TK
    http://dynomotion.com
    Jun 2004
    Scotland
    Nothing stands out in the init file to me, that would cause things not to work.
    Try running the init file and jogging, with KMotion open in the background, with the Console and Axis screens open.
    Are there any messages shown in the console, and do the axis remain enabled in the Axis Screen?
    May 2006
    Hi Owen,
    Sorry I missed the attached file. I also don't see any issue. Except an input gain of -2 which is a bit odd but shouldn't cause that problem.
    Are you sure that is the program you are running? You describe it using a different name.
    Regards
    TK
    Apr 2013
    Tom
    Pretty sure its the file
    because:
    initially couldn't upload it so shortened file name then realized the file type needed to be txt not c doh!
    My next move will be to try the kmotioncnc with kmotion up in the background
    then to try with only axis 0 then only axis 1 and then 2
    and I'll change the gain to -1 just for the heck of it
    As a second question the SetBit for 152 157 158 were copied with original init for DAC ?needed or not?
    Owen
    May 2006
    Hi Owen,
    If those FET Outputs aren't needed to enable your Drives then they can be removed.
    Regards
    TK
  7. #7
    Apr 2013
    problem solved for those wish to know
    the issue was
    ch1->LimitSwitchOptions=0x12f;
    ch1->LimitSwitchNegBit=138;
    ch1->LimitSwitchPosBit=138;
    which needed to be changed to
    ch1->LimitSwitchOptions=0x100;
    ch1->LimitSwitchNegBit=0;
    ch1->LimitSwitchPosBit=0;
    i.e. so that the axis when activated would not stop all movement how dumb can I get !!
    owen
