New Machine Build Wire Processing Robot - by True Machine Design - using GoldCNC5 running on KFlop.
Results 1 to 2 of 2
Thread: Wire Processing Robot - by True Machine Design - using GoldCNC5 running on KFlop.
    Registered jeffserv's Avatar
    Jul 2004
    Default Wire Processing Robot - by True Machine Design - using GoldCNC5 running on KFlop.
    Hi All,
    Over the winter, I built this Wire Processing Robot; to make wires for the UL508a panels we build at True Machine Automation. May turn 4 days of wire making into approx. two days.
    This is our GoldCNC5 running on the KFlop Motion Board, One Konnect Board; running KMotion ver. 4.33.
    All this machine, is run using 1 GCode program and MCodes for running "C" programs and Inputs and Outputs.
    This machine has X, Y, Z, A (Rotate Effector), C (Wire Feed). Some new parts, mostly surplus from previous jobs.
    So far KFlop and KMotion has done everything I wanted it to... really like the system.
    - Jeff Redington
    Video
    GOLDCNC5, BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - www.truemachineautomation.com
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Wire Processing Robot - by True Machine Design - using GoldCNC5 running on KFlop.
    That is downright cool. Amazing the number of tasks you were able to perform with the single 4 axis robot.
    TK
    http://dynomotion.com
