Hurco BMC20 Dynomotion Retrofit - Page 8
Page 8 of 29 FirstFirst ... 56789101118 ... LastLast
Results 85 to 96 of 347
Thread: Hurco BMC20 Dynomotion Retrofit
  1. #85
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Hurco BMC20 Dynomotion Retrofit
    Hi Troy,
    You did things differently than I intended. I didn't intend to have a voltage divider. Just a single 150ohm load. And I expected to read the voltage at the output.
    But that is ok. If I understand what you did.
    You call out "V-GND" and "Powersupply GROUND". Are those the same thing?
    Where is the scope GND connected?
    I think the output might be driving 24V (with a 24V supply) through a 2K Resistor (as seen on the PCB marked 202 - 20 and add 2 zeros). In that case we would expect to have at your scope connection:
    24V x 150ohms / (150ohms + 150ohms + 2000ohms) = 1.56V
    Did you mean to say 1.5V or 1.05V ?
    Regards
    TK
    http://dynomotion.com
  2. #86
    Registered Need TECH Help!'s Avatar
    Dec 2007
    Yes V-GND and Powersupply GROUND are the same.
    Scope GND is not connected. Did not know where to connect it. I have not used a scope much so my understanding of one is low.
    1.05V channel output with 100ohm voltage divider.
    If i use a resistance of 155 ohms to gnd. I get an output of 1.71 Volts and when output toggle off, voltage reads 74.1 mV.
    Troy
    http://www.homecncstuff.elementfx.com/
  3. #87
    May 2006
    Hi Troy,
    You should connect the Scope Probe GND to the GND of whatever you are measuring. In this case V-GND.
    Note some scopes have a connection from their GND to Earth GND. (which is why it may be working without any GND). I usually disconnect that using a GND isolation Plug on the scope. You might want to determine if your scope has a connection to Earth GND by using an Ohm meter. Its nice to know.
    Is your 24V supply isolated from Earth GND?
    But anyway that seems to make sense now with 100 ohm resistors:
    24V x 100ohms / (100ohms + 100ohms + 2000ohms) = 1.09V (close enough)
    I think we now need to decide where to connect it to KFLOP/Kanalog/Konnect. The main decision is whether it needs to be connected to a hardware encoder input or software encoder input. Hardware is good because it can handle high speed counting up to 1MHz. But has the disadvantage of limited pins, voltages, etc... Software is good because any inputs can be used. But has the disadvantage of a max count rate of ~3KHz. That is usually adequate for most MPGs. I'd suggest trying Software first because it is easy and if there are any issues with spinning the MPG fast figure out a hardware solution.
    Since Konnect has screw terminals and can accept 24V signals I'd try that. Connect a Konnect Common to V-GND and the A B signals directly to the Konnect Inputs. Konnect Inputs are like a 4K Ohm load so they should be driven to:
    24V x 4K / (2K+4K) = 16V
    Regards
    TK
  4. #88
    Dec 2007
    Yes, scope has connection to earth ground.
    Benchtop power supply is not isolated from Earth Ground. Shows about .8 ohms.
    Will do on connecting to Konnect. It will be a while before i get to test it out.Still need to make cable for pendant. And finish wiring diagrams, I have about 90% of my wiring diagrams done for mill. Next to sort out is the VFD Rs485 to Rs232 RedLion converter so i can interface to Kanalog.
    Thanks again for help and patience
    Troy
  5. #89
    Dec 2007
    Working on VFD to Kanalog connection. Making the RS232 cabling for RS485 converter . The converter iam using is a RedLion ICM5. The converter has dip switches to set it as a DTE or DCE device. Am i understanding correctly that it should be set as a DTE device and Kanalog JP10 is the DCE device?
    Troy
    Attached Thumbnails Attached Thumbnails Hurco BMC20 Dynomotion Retrofit-red-lion-rs232tors485-pdf
  6. #90
    May 2006
    That sounds correct to me. The normal idea with RS232 is to have one device talk (TX) to pin 2 and one device listen (RX) to pin 2. But the other piece of the puzzle is how the cables are made.
    Regards
    TK
  7. #91
    Dec 2007
    Here is an xls sheet of my cable connection for RS232. Not sure about sheild drain thow. I show it being connected to GND pin at Kanalog JP10. The manual of Kanalog show shields on pins 7 & 8, but where is this as JP10 is only 6 pins?
    Troy
    Attached Files Attached Files
  8. #92
    May 2006
    Hi Troy,
    Pin 1 is also Kanalog GND which might be used for the shield.
    Regards
    TK
  9. #93
    Dec 2007
    Default Kanalog SWE switch wiring
    I plan to use Kanalog's JP8 Switch Enable All (SWE) output for my main Machine Control Relay/Contactor. The contactor coil will be controlled by a solid state relay(SSR) and this solid state relay will be controlled by Kanalog's Switch Enable All output. The SSR operates off of 3-32VDC. How would i wire this to Kanalog SWE?
    Example: Connect +24VDC power supply to plus side of SSR control input and Kanalog SWE output to minus side of SSR control input. Then connect the 24VDC power supply minus side to a Kanalog JP6 ground terminal?
    Looking at the Kanalog manual on JP8 and iam kinda lost on how the FET switch ground makes a connection for the 24VDC supply minus.
    Thanks for any help,
    Troy
  10. #94
    May 2006
    Hi Troy,
    Yes
    The Kanalog FET Switch Grounds are not isolated they they are internally connected and are the same as all Kanalog (and KFLOP) GNDs. Usually they drive something like your SSR which provides Isolation anyway. So you must connect the associated 24V Supply GND to Kanalog GND. Note that if you then use this same 24V supply for other opto isolated circuitry that circuitry will not be isolated.
    HTH
    Regards
    TK
  11. #95
    May 2012
    canada
    Default Re: Kanalog SWE switch wiring
    Quote Originally Posted by Need TECH Help! View Post
    Troy
    I dont think the enable all switch is controllable from Kflop, i think it just conducts once it boots up. Because of this I passed through one of the optical outs and then to the enable all output. I use these two outputs together (both need to be on) to control a SSR in the E-stop loop. This way the machine is guaranteed to be off on startup, and you can cut power to everything by controlling that output which is handy.
  12. #96
    Dec 2007
    Quote Originally Posted by mmurray70 View Post
    Maybe iam misunderstanding something, i read in another thread where Tom said "One thing you should be aware of is that for several seconds while Kanalog is powering up the Outputs may be in a random state (sorry about that). There is a signal SWE (Switch enable) that is guaranteed to remain off until all the other IO is initialized off. So you may want to setup to use SWE as a master disable for everything."
    How is the SWE controlling your EStop loop at boot up if the optical output is not active? Trying to picture your connections.
