Hurco BMC20 Dynomotion Retrofit - Page 28
Page 28 of 28 FirstFirst ... 1825262728
Results 325 to 333 of 333
Thread: Hurco BMC20 Dynomotion Retrofit
  1. #325
    Registered Need TECH Help!'s Avatar
    Dec 2007
    Default Re: Hurco BMC20 Dynomotion Retrofit
    Looks like you understand it more than a little murray
    A 2016 Hurco is the only machine i have ran that allows a feedhold during tap cycle its nice as it keeps the kosher way of controlling a machine. Its more common in a questionable/new operation to feedhold so during a tap cyccle the feedhold would be more of a natural reflex. Been several times during a tapcycle on other machines that i tried to feedhold. But iam up for what is the safest,sure way to handle this for everyone. Which is most likely just blocking the factory feedhold buttons during tapcycle as murray has said.
    http://www.homecncstuff.elementfx.com/
  2. #326
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Troy/mmurry70,
    Here is a patch that changes the Interpreter to expose if it is currently in a tap cycle.
    KMotionCNC is changed where if FeedHold is pushed while in a tap cycle instead of feedholding it will flag the M119 Tap program (by setting persist Var+0 to -1). It should also show the Feedhold DualButtonState image correctly based on the persist Var state.
    It will then be up to the Tap Program to detect the Var set to -1 and stop the spindle. The Resume Button will then Clear the Var to 0 to tell the Tap Program to restart the spindle in the recorded direction.
    To solve the problem where the operator pushes Feedhold just exactly before a Tap Cycle and XYZ begins feedholding and then the TAP cycle begins, the Tap Program must detect any motion Feedhold, release it, and trigger a "Tap" feedhold.
    Does any of this make sense?
    Here is the GCodeInterpreter that exports Tap Cycle State:
    http://dynomotion.com/Software/Patch...nterpreter.dll
    Here is the KMotionCNC that handles Tap Feedhold:
    http://dynomotion.com/Software/Patch...KMotionCNC.exe
    Here is a modified Tap c Program that includes monitoring for Tap Feedhold:
    http://dynomotion.com/Software/Patch...ld%20Rev%204.c
    Could you test to see how much of it works?
    Regards
    TK
  3. #327
    Dec 2007
    Tom,
    Tested your files. As soon as Tapcycle is started the spindle shuts off but stays synced. Then if i manual switch on spindle tapcycle finishes for 1st hole and spindle shuts off again after 2nd hole is started.
    Feedhold works correctly for the X axis feedmove and is ignored during tapcycle.
    Other than spindle turning off all appears to be working.
  4. #328
    May 2006
    Hi Troy,
    Opps Var+0 was already being set to -1 causing an immediate Tap Feedhold. Lets use -2 to command a Tap Feedhold.
    The patch KMotionCNC.exe and Tap C Program have been updated to use -2.
    Please try it again.
    TK
  5. #329
    Dec 2007
    Hi Tom,
    That fixed the spindle shut off issue. Going to try a few more test scenarios air and then try a test in plastic. Plastic should show any sync issues with breaking tool.
    Thanks again,
    Troy
  6. #330
    May 2012
    canada
    Nice work Tom, that looks great. I might try the new code on my machine someday too.
    Troy, if you want to check how well its synced try tapping a piece of flatbar extended out over the edge of a vise and put an indicator on it. The part will be able to deflect a little and the indicator will show how well spindle is following the tap. My machine was less then 0.005" and i had some slop in Z axis at the time. I was pretty happy with that. Trying plastic or something soft isnt a bad idea first.
  7. #331
    Dec 2007
    Ok. Tried tapping 1/4-20 in plastic, alluminum and then C.R.S. all tapped well. And the steel thread had a very good fit. Only had a used hand tap. Will need a new power tap to do an accurate deflection test. But i think its good just by the how the steel tapped.
    Thanks again,
    Troy
  8. #332
    May 2012
    canada
    Good to hear its working well, your probably fine if taps are not breaking and threads are a good fit.
    I peck tapped some 10-32 holes in stainless today and it worked well. One minor issue is it starts pecking immediately from the R plane. I was pecking only 1 turn at a time today so there were several pecks before it cut anything. Ill try and fix this someday when i get a chance, shouldnt be too hard.
  9. #333
    May 2012
    canada
    Actually forget about what i said above. The top of work piece isnt even defined in G84, only the R plane and depth so it has to work the way it is now.
