Looking for a program to use a touch probe to create a point cloud with KMotionCNC
Results 1 to 7 of 7
Thread: Looking for a program to use a touch probe to create a point cloud with KMotionCNC
    Dec 2010
    Default Looking for a program to use a touch probe to create a point cloud with KMotionCNC
    The last reason to keep Mach3 w/ 2010 Screen set on my machine since I switched to KMotionCNC is for the probing routines. I have figured out probing for offsets and centers but I am still not able to digitize a point cloud. I have not figured out how to write the data to a file. I have seen several posts regarding this issue but have not heard of any results. Anyone willing to share before I reinvent the wheel?
    Member TomKerekes's Avatar
    May 2006
    Default Re: Looking for a program to use a touch probe to create a point cloud with KMotionCN
    Hi JoeKumanchik.
    I'm not aware of anything specifically but it shouldn't be too difficult to create. Can you be more specific? Do you plan to probe in z over an xy array of points? Always start probing from a fixed height? What output format do you require?
    Regards
    Regards
    TK http://dynomotion.com
    Dec 2010
    Hi Tom,
    Thanks for the quick response. You are correct, the plan is to probe in Z for an X Y array of points. The file type can be a simple .txt that has the X, Y, Z coordinates for each point of the array. And yes, the height of the Z would be fixed. My thought is to generate the probing array in G Code with a custom written M code to output the XYZ position when the probe switch trips.If I understand correctly, Kflop supports writing files but once the file is closed, opening it again would wriote over the old data.
    May 2006
    Hi JoeKumanchik
    One approach might be to define three M Codes. One Opens a file for writing. One Writes a xyz value to the file. One Closes the file.
    Your GCode could then open the file, loop measuring all the points, then close the file.
    HTH
    Regards
    Regards
    Dec 2010
    Thanks Tom, a quick test last night using this method looks promising. Very simple solution.
    Dec 2009
    Hi if your using Mach3 I have allready made all the probes you should ever need including 4th axis with conversion to full point cloud
    search cnczone for "squirrel probes"
  7. #7
    Dec 2010
    Thanks for the information Squirrl_44. I will download and have a look. My goal is to replicate some of the probing routines found in the 2010 screen set into KmotionCNC but it is easy enough switch back to Mach3 to run digitizing routines until i figure it all out i n Kmotion
