Newbie NET S code
Results 1 to 4 of 4
Thread: NET S code
    Mar 2012
    Default NET S code
    NET with M code is used
    .CoordMotion.Interpreter.SetMcodeAction(6, KMotion_dotNet.MCODE_TYPE.M_Action_Program_wait_sync, 2, 9, 0, 0, 0, Application.StartupPath & "\C_Program\Home\CambioUt.c")
    S code?
    Thank you
    Oct 2004
    Quote Originally Posted by Fledge2b View Post
    S code?
    Thank you
    For c# using the '&' character to join 2 Strings is incorrect. Use a '+' sign instead. Also '\' characters need to be escaped.
    Use
    Application.StartupPath + "\\C_Program\\Home\\CambioUt.c"
    Or
    Path.Combine (Application.StartupPath, @"\C_Program\Home\CambioUt.c")
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: NET S code
    Hi Fledge2b,
    What are you trying to do?
    What happens?
    I believe the S command is Action 10 not 6. 6 is M6 ToolChange
    Regards
    TK
    http://dynomotion.com
    Mar 2012
    I'm developing a software vb net and used for tool change M6
    SetMcodeAction (6, KMotion_dotNet.MCODE_TYPE.M_Action_Program_wait_sync, 2 etc. Etc.
    instead for S
    SetMcodeAction (10, KMotion_dotNet.MCODE_TYPE.M_Action_Program_wait_sync
    S use ... SetMcodeAction ....... led me astray the function name
    OK thanks
NET S code
NET S code
