Mach 3 or Kflop buffering commands? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 22 of 22
Thread: Mach 3 or Kflop buffering commands?
  1. #13
    Jun 2004
    Scotland
    Default Re: Mach 3 or Kflop buffering commands?
    What does the axis screen in KMotion show when you initialise Mach?
    To me it's like there is a commanded move being generated somewhere.
    Might be worth attaching your latest init, and mach xml file.
  2. #14
    May 2013
    Prior to initialization the Axis screen shows 0 for Dest and close to zero for Position (most i saw was 12). All axis disabled.
    I will get and post the init and xml file Sunday.
    Cheers
    Chris
  3. #15
    Jun 2004
    Scotland
    And what happens with the destination/position during initialisation?
    Do you think the axis is being powered downward, or dropping under gravity?
    It can be quite surprising how easily/quickly quills/heads will drop under gravity. It could be worth trying to apply a bit friction to the ballscrew/motor/belt so it definitely can't move just by gravity.
  4. #16
    May 2013
    I will check, but if it was falling under gravity wouldn't it try to correct upwards instead of driving it downwards? I do see the feedrate in Mach go to 120 briefly which is the max speed so it appears to be driven.
    Cheers
    Chris
  5. #17
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Chris,
    You might post your Initialization Program so we can see how things are being initialized and handled.
    You might also observe the KMotion Axis Screen's Commanded Destination and Encoder Position before and after initializing and the motion downward.
    One possible scenario is that your Z axis servo doesn't have any Integrator gain and because of gravity the actual position is significantly below the commanded position. Normally when enabling the axes the target Destination is set to the current Position as an attempt not to move much. However in this scenario the result will be a step downward each time the system is initialized. For example say the Commanded Position is 1000 but due to gravity the Position drops to 900. If the system is re-initialized and sets the Commanded position to where it is (900) the position will then drop to 800.
    HTH
    Regards
    TK
    http://dynomotion.com
  6. #18
    May 2013
    Init program is posted above (init_new.txt) only change is I have been adjusting the max following error.
    I will take pics of the Axis screen tomorrow.
    Cheers
    Chris
  7. #19
    May 2013
    Ok, after playing with it some more and manually releasing the brake to see how fast the z axis moves down under gravity I am leaning more and more towards the control loop/drive power is not fast enough to catch the initial drop of the Z axis when the brake is removed. So either I need to power the drives and enable control then wait a second before releasing the brake or I need to speed up the response of the control loop (assuming the drive enable gets power to the drives fast enough).
    I have attached pics of the axis screen on a fresh restart and when it faults after the first and second reset in Mach. Also attatched is the current init program and a console capture.
    Cheers
    Chris
    Attached Thumbnails Attached Thumbnails Mach 3 or Kflop buffering commands?-mach-reset-1-jpg   Mach 3 or Kflop buffering commands?-pre-enable-jpg   Mach 3 or Kflop buffering commands?-mach-reset-2-jpg   Mach 3 or Kflop buffering commands?-console-jpg
    Attached Files Attached Files
  8. #20
    Jun 2004
    Scotland
    Do you have a link to a manual for the servo/drives?
  9. #21
    May 2013
    I could never find manuals for these drives unfortunately.
    They are Allen-Bradley Bulletin 1389 Servo Amplifiers
    X-Axis - 1389-AA17
    Y-Axis - 1389-AA09
    Z-Axis - 1389-AA09
    The power supply is Bulletin 1389 Power Supply - 1389-PAT10
    I have attached the files I could find.
    Attached Thumbnails Attached Thumbnails Mach 3 or Kflop buffering commands?-1389-connection-guide-pdf   Mach 3 or Kflop buffering commands?-1389-ac-drive-parts-list-pdf   Mach 3 or Kflop buffering commands?-1389-troubleshooting-guide-pdf
  10. #22
    May 2006
    Hi Chris,
    I suspect the issue might be that you are having Mach3 enable the Drives (and release the brake) and then later Mach3 performs the Initialization C Program that starts the Servo. If these don't happen at the same time then the axis will be falling in the meantime. Or conversely the Servo can go nuts if enabled with the drives disabled and the brake on. I'm not sure what order Mach3 does things. I thought I read somewhere that Mach3 enables the axes one at a time with a delay between them as an attempt to avoid a current surge of all of them enabled at the same time.
    Try having KFLOP enable the Drives at the same time as it enables the KFLOP Axes. You may want to configure the Mach3 Enable Outputs to dummy or Virtual IO Bits.
    HTH
    Regards
    TK
