Newbie atc on kflop
Results 1 to 7 of 7
Thread: atc on kflop
    Aug 2015
    Default atc on kflop
    Hi everyone! first-sorry for my english=). Second- i want place encoder on my spindel for tracking position. It need for atc. I have wire from encoder. where they need to connect? to kanalog/kflop or something another? Maybe this question be here early but i can't find.
    May 2012
    canada
    Default Re: atc on kflop
    You will probably need something to lock it as well unless maybe you have the spindle set up like a servo somehow.
    My Fadal uses a small air cylinder with a roller on it, and theres a ring on the spindle with a notch in it. Theres also a hall effect sensor that activates when notch lines up. Probably wouldnt be hard to make a setup like this.
    On my machine now to orientate i turn spindle on slowly, delay for a while to let it reach speed, wait for it to see sensor, delay again until close to notch in next rotation, then turn off spindle and enguage air cylinder. Adjust speed and delay until it stops in notch smoothly. good luck with it
    Aug 2015
    Thx! But mechanical part is not a problem.I asked about connecting encoder to kflop.
    Jun 2004
    Scotland
    What kind of encoder?
    May 2012
    canada
    ok sorry, when you said encoder for spindle needed for ATC it sounded like you were trying to figure out orientation. Best of luck with it anyway.
    Member TomKerekes's Avatar
    May 2006
    Regards
    TK http://dynomotion.com
  7. #7
    Aug 2015
    thx to all!
atc on kflop
atc on kflop
