Need Help! Problem jig grinding machine. - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 55 of 55
Thread: Problem jig grinding machine.
  1. #49
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: Problem jig grinding machine.
    Hi vadim_cnc,
    One more question, can this board (KFLOP) accumulate an error while working?
    After 3 hours of the cycle in which the axis moves, the range of movement has decreased. Maybe it is associated with the old age of our equipment (such as an electric drive).
    Maybe You know something about it?
    No, KFLOP should not accumulate any error. Have you resolved this? It might be you have a noise problem causing gain or loss of encoder counts. That would cause a position drift not a reduction of range of movement.
    Regards
    TK
    http://dynomotion.com
  2. #50
    Nov 2016
    Hi, Tom!
    Thanks for clarifying. Of course it may be a problem with a linear encoder (released in the 80s) and unshielded wires. But the most problem we think is hydraulic station, which cannot provide necessary power.
    Best regards!
  3. #51
    May 2006
    Hi vadim_cnc,
    Normally if the encoder was working correctly and the hydraulic station didn't have enough power to move correctly you would receive an error. So that is why I was thinking it might be an encoder issue.
    Regards
    TK
  4. #52
    Nov 2016
    Hi, Tom!
    There is another question: how to read variable, which recorded by G-code string?
    For example to read Speed variable (S) we used persist.UserData[SPEEDVAR]
    Code:
    #include "KMotionDef.h"
    #include "MySpindleDefs.h"
    main()
    float speed = *(float *)&persist.UserData[SPEEDVAR];  // value stored is actually a float
    Jog (4, -speed*166.6667);
    SetBit (146);
    It is possible to get feed rate value (F) from G-code (for use it in script)? Also maybe it possible to add custom variable to G-code string, for example:
    M105 X50 F300 AA85 BB95 CC99
    where AA, BB, CC - custom variables
    Best regards!
  5. #53
    May 2006
    Hi vadim_cnc,
    The Feedrate value is not normally available to a KFLOP C Program. You can determine the axes velocities. You might look at the VelocityToPWM.c example.
    Well no, but what are you trying to do? GCode has Variables. You can call M Codes with PQR parameters. See:
    MCodes with Parameters
    Regards
    TK
  6. #54
    Nov 2016
    Hi, Tom!
    M code with parameters works well! Thanks!
    P.S. We trying to make cyclical moving of gidraulic cylinder. But there is need some parameters, like start and end coordinates and speed.
    P.P.S. Now it works!
  7. #55
    May 2006
    Hi vadim_cnc,
    Great! Where is the Video?
    Regards
    TK
