Hi Bengt,
Before jumping ahead to using closed loop Step/Direction you should verify that open loop Step/Dir is working first. It's less confusing if you go step-by-step and verify each step is working correctly before proceeding to the next step. The basic sequence is:
#1 - verify the Step/Dir signals to the Drive are working open loop. Commanding a motion to the drive should move the correct distance. Returning back should repeat to the original position. There should be no drift in physical position after repeated moves.
#2 - verify the Encoder feedback is working correctly. Commanding a motion the Encoder position (red) should follow the Command (blue) with only small errors. There should be no drift in measured Encoder position after repeated moves. Observe the amount of following error.
#3 - enable closed loop control.
It would be simpler to work with one axis at a time.
Instead of photographing the screens take a screen shot using alt-print screen Then paste into a program like paint.exe and save to a *.png file.
Regards
