Hi Kevin,
You might have KFLOP perform a logic operation on two inputs to set a single virtual I/O bit. Then configure the Mach3 Probe bit and notification C program to watch for the virtual bit. The logic operation will need to be in a loop that gets executed continuously. Such as the following will set virtual bit 48 if input 0 goes high or if input 1 goes low:
HTHCode:#include "KMotionDef.h" main() { for(;;) { if (ReadBit(0) || !ReadBit(1)) SetBit(48); else ClearBit(48); } }
Regards
