Hi Eddard_Stark,
Try disconnecting everything from KFLOP. Cycle Power on KFLOP to place KFLOP in a default un-configured state. Do not run any configuration program or download any configuration. Can you set its 26-35 as Outputs and toggle them individually on an off? If not then KFLOP may be damaged.Now when in KMotion.exe, bits 26 - 35 seemingly randomly toggle on and off. Some are permanently in checked state. Did I do permanent damage to the board?
The 24V Konnect Inputs shouldn't be susceptible to damage from a few volts of ground noise like a KFLOP input would be. Something like this should work:
Regards
