- Adjusting distance errors K2 CNC
as you may recall, a few months back i upgraded my computer and software and in the migration process whiped out some important data.
Tom was nice enough to assist and getting it back up and running, however I recently noticed that the actual cutting distance is off and am looking for info on how to adjust this.
I dont have Mach 3, just kmotion 429
any help is greatly appreciated
Re: Adjusting distance errors K2 CNC
Are you using KMotionCNC as the interface?
If it is, then if you go into tool setup, then the Trajectory planner tab, there should be a Counts per Inch setting for each axis.
You'll either need to calculate the steps per inch, or accurately measure a long distance and do some calculations to work out the correct steps per inch.
ok, sweet I think i can figure that out. Thanks !
- You may not post replies
- You may not edit your posts
Forum Rules
