So it looks like I"m gonna need 6 control pins. I would like to take advantage of the Current sense pin so this is what I assume
Power goes to 5V Pin 24 or 23
Ground goes to digital ground Pin 25 or 26
Left enable --- Some output pin
Right enable --- Some output pin
L-PWM- Output 0
R-PWM- Output 1
This is one thing I found that Kind of points me in the right direction but not quite sure. I'm not much of a programmer.
#include "KMotionDef.h"
// Example showing how any of the 8 Step and Direction
// frequency generators may be used as a PWM
//STEP_RATE_ADD 0x3c - write a 32 bit word - Bit31=enable, Bit27=Drive, Bits24-26=chan, 0-23= signed fraction of 16.666MHz
//STEP_PULSE_LENGTH_ADD 0x06 - write a 6 bit word - 0-63 = # of 16.666MHz clocks to this address
#define CLOCK 16.6666e6
main()
double DutyCycle, Period;
int Frequency;
int Pulse=50; // Fixed pulse length of 50/16.66MHz = 2us
int StepChan = 1; // KFLOP Step Gen #1 IO10 Pin 17
SetBitDirection(10,1);
FPGA(STEP_PULSE_LENGTH_ADD) = Pulse;
DutyCycle= 0.33; // Note Duty Cycle can't be zero (useful range 0.02 - 0.98)
Period = Pulse/DutyCycle;
Frequency = (int)(0x7FFFFF/Period);
printf("DutyCycle=%f, Pulse=%d clocks, Period=%f clocks\n",DutyCycle,Pulse,Period);
FPGA(STEP_RATE_ADD+0) = Frequency; // put 23 bit frequency
FPGA(STEP_RATE_ADD+1) = Frequency>>8;
FPGA(STEP_RATE_ADD+2) = Frequency>>16;
FPGA(STEP_RATE_ADD+3) = 0x88 + StepChan; // combine enable, Drive High and low mode, channel
