Hi Mac7988,
Yes. The included HomeMach3.c only prints messages to the Console received from Mach3 to the KMotion.exe Console Screen. Are you seeing those?1) Do you need to modify the Homemach3.c if so can I get an example on how to do that?
The first step is to figure out how to home your axes using KMotion.exe C Programs. Then once you have code that works for each of your axes merge it into the HomeMach3.c program. See the example SimpleHomeIndexFunctionTest.c
Yes. The limits must be saved and disabled, then after homing and moving out of the limit they can be re-enabled. The SimpleHomeIndexFunction does this for you.Can I use a limit switch as my home switch?
Not normallyDo I need to setup or modify anything in Mach3?
HTH
Regards
