- Need Help!- SingleStep
SingleStep
Hello,
I have a 5 axis CNC machine using dynomotion,
I'm using KmotionCNC as my interface
is there any way i could add a button that do single steps and not execute the hole program
I'm having an issue while executing the program i think is caused by the trajcetory planner lookahead time but reducing it is no option because it messes up my motion
i want to execute each line alone but with a press of a button and not having to press single step at the end of each line
thanks all for your help
Charbel Y.
Re: SingleStep
Insert a Dwell or delay at the end of each line in Mach3
For a delay or dwell in G-Code use code G4.
eg. to insert a delay of 5 sec use the line:
G4 P5
Will let program run through without intervention but allow you TIME to stop or pause during the delays,
- You may not post replies
- You may not edit your posts
Forum Rules
