Hi kdoske,
Looks like you are double posting questions.
Did you read my response on the Yahoo Group?
Regards
Afternoon all,
I use the example code below and nothing happens. I printed the persist.UserData[1] array to console and its empty. When I hard code 'speed = 12000' everything hardware wise works as it should and my VFD drive goes to the appropriate HZ (in this case 200hz).
What am I missing? When and where is persist.UserData[1] updated with the current Gcode S value? Is this something I have to add somewhere else? I don't see any sign of it in any of the default config files either.
main()
float speed = *(float *)&persist.UserData[1]; // value stored is actually a float
printf("speed=%f UserData1=%f\n",speed,persist.UserData[1]);
FPGA(KAN_TRIG_REG)=4; // Mux PWM0 to JP7 Pin5 IO 44 for KSTEP
SetBitDirection(44,1); // define bit as an output
FPGA(IO_PWMS_PRESCALE) = 46; // divide clock by 46 (1.4 KHz)
FPGA(IO_PWMS+1) = 1; // Enable
FPGA(IO_PWMS) = CorrectAnalog(speed/RPM_FACTOR); // Set PWM
If i do this everything works hardware wise. So all my connections are good.
main()
speed = 12000;
printf("speed=%f\n,speed);
Hi kdoske,
Regards
Regards
TK http://dynomotion.com
Sorry, when I realized that there was support on here I removed my yahoo post since its not something I will ever use. I added your post to here below.
Oh, so that's what the VAR field is for? Its to late to try now, but I assume that when execute program is selected a value is passed to the VAR/Array index number indicated?
Do all of the commands on the M0-M30 pass a value of some kind? Is there anywhere this is all broken down more clearly?
Tool Setup Screen M3-M9
This location talked about Execute Prog but only mentions that the VAR is a 'persistent variable' set at runtime. It doesn't mention whats stored in it and what variable/array it even passes its value in is called so it can be accessed at a later time. Of course now I see based on the example and you mentioning it here, but shouldn't all this be stated in the same area instead of it being spread across 2 or 3 different areas like it probably is?
Am I crazy? The board seems fantastic but the docs for this thing are spaghetti. Thanks for your time.
Ouch. If you knew how much effort we put into hundreds and hundreds of pages of documents, on-line help, examples, articles, wiki, Forum Posts, etc and how we attempt to hyper-link parameter descriptions like this 1 mouse click away you might understand how it hurts to have it dismissed as "spaghetti". That is certainly our biggest complaint and thanks for the feedback. If you couldn't all find the info you needed quickly then we failed.
Your link does describe what is stored in the Var for the S Word with:
S - Spindle Speed Setting. If C Program is specified Speed in RPM is passed to the specified KFLOP Var as a 32-bit floating point number
Many of the "Actions" don't have any associated data to pass to a C Program. For example M3 is to turn on the Spindle and no Var information is really needed. In those cases where data isn't specified the M Code Number is placed in the Variable. This can allow multiple Actions to be serviced by a single C Program if that works out easier.
HTH
Regards
Regards
Tom,
Thanks alot for the additional info Tom.
Sorry I was so blunt but I do feel that way. I took way more time then I should and I created what I believe to be a much cleaner and comprehensive way to break down the M-0 to M30 Tab. Its attached here in a word doc. I'm not saying use this exactly but it would definitely in my opinion alleviate a lot of questions. If the whole manual was done this way I bet it would cut customer support down as well. Anyway, not trying to step on toes. Just thought I would help. Thanks again.
https://drive.google.com/file/d/0B7h...ew?usp=sharing
